20 Most Recent
Fisher and Paykel 24 in. DD603H I Built-in Dishwasher Questions & Answers
F9 beeping
Its a most common problem in this kind of model. The reason for F9 display in your washer is that due to a electronic malfunction that occured in your unit. You cant replace any of the faulty part in your washer and its very difficult to identify the faulty area in your unit. So if you think you can do it by your own then the answer is "NO"..
Best way to fix your problem is that call your authorized service centre and they will fix your problem for sure..
Dish washer not cleaning properly
I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher
SprayArms not Spinning
How to Buy
ApplianceParts OnlineA bad heating element causes many problems in dishwashers...
Dishwasher Problems The
HeatingElement not WorkingDishwasherMaintenance
DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
[p]
][p
Fisher Paykal DD60 dishwasher - strange issue - beeping when needs to drain
If your Fisher Paykel DD60 dishwasher is beeping when it needs to drain, it may be experiencing a drainage issue. Here are some steps you can try to diagnose and fix the problem:
- Check for Blockages: Make sure that there are no blockages in the drainage hose or filter. A blocked drainage hose or filter can prevent the dishwasher from draining properly, which can trigger the beeping sound. Remove any blockages that you find.
- Check the Drain Pump: The drain pump may be faulty, which can prevent the dishwasher from draining properly. Check the pump to ensure that it is functioning correctly. If the pump is not working, it may need to be replaced.
- Check the Drain Valve: The drain valve may be faulty, which can prevent the dishwasher from draining properly. Check the valve to ensure that it is functioning correctly. If the valve is not working, it may need to be replaced.
- Check the Control Board: The control board is the brain of the dishwasher and controls all the functions. If it is faulty, it can cause the dishwasher to not operate correctly. Try resetting the control board or replacing it if it is faulty.
- Check the Sensor: The sensor may be faulty, which can cause the dishwasher to beep when it needs to drain. Try cleaning the sensor or replacing it if it is faulty.
If none of the above steps work, it may be best to contact a professional technician for further diagnosis and repair. They can inspect the dishwasher thoroughly and ensure that it is working correctly and safely.
What error code is on Fisher and Paykel dishdrawer DD60DDFX9 flashing leds
About the F4 error code on the Fisher and Paykel DD60DDFX9 dishwasher:
The F4 error code on your DD60DDFX9 dishwasher indicates a fault with the heating element or the temperature sensor. When the dishwasher encounters a heating fault, it is unable to heat the water to the correct temperature required for the wash and rinse cycles. This can result in poor cleaning performance and may also affect the dishwasher's ability to sanitize the dishes.
To troubleshoot the F4 error code, you can try the following:
- Check the heating element: Use a multimeter to test the heating element for continuity. If the heating element is faulty, it will need to be replaced.
- Check the temperature sensor: Test the temperature sensor using a multimeter. The sensor should show a resistance value of between 10,000 and 12,000 ohms at room temperature. If the resistance value is outside of this range, the sensor may need to be replaced.
- Check the wiring and connections: Inspect the wiring and connections between the heating element and the control board. Make sure all connections are secure and free of damage or corrosion.
- Check the control board: If the heating element and temperature sensor are both working properly, the issue may be with the control board. A certified repair technician will need to diagnose and replace the control board if necessary.
Dishwasher Fisher and Paykel DD24SCTW9 dishdrawer LCD display is out
If there is no light or display on the LCD and the buttons are not functioning on your washing machine, and you have verified that there is power to the motor controller module and the wash controller module, it is possible that the issue is with the LCD or the ribbon cable that connects the LCD to the control board.
To narrow down the location of the fault, you can try the following steps:
- Check the ribbon cable: Inspect the ribbon cable for any visible damage or loose connections. You can also try gently wiggling the cable to see if this affects the display.
- Check the control board: The control board is responsible for controlling the various functions of the washing machine, including the LCD. If the control board is faulty, it can cause issues with the LCD.
- Check the LCD: The LCD itself may be faulty and not functioning properly.
If you are unable to diagnose and fix the problem on your own, it is recommended to have a mechanic or appliance repair technician take a look at the washing machine. They will have the necessary tools and expertise to properly diagnose and repair the issue.
Fisher and Paykel DD603 can't be drained completely
https://www.manualslib.com/manual/575481/Fisher-And-Paykel-Dishdrawer-Dd603.html?page=22#manual this link takes you to the service manual for your machine, there will be details on manually testing individual components, you should be able to operate the pump and check that it is performing as it should, page 39 describes the process to lift out the rotor, do that and check the rotor impeller, this is the drain pump, if the rotor vanes are broken you will need to replace it,
F&P dishwasher (DD603i) has no power to top drawer
No power to the top drawer needs to be verified.
Are you saying the lights are blank and when you press the start buttion nothing happens?
One reason the controller can shut the power is that the heater overload protection thermal resistor has opened. Unfortunately the only way to fix this is to replace the entire heater plate at the bottom of the drawer.
To confirm if the controller is operational or not, press Keylock and Start/ Pause button together for 5 sec (press Keylock first) and see if the Lights light up. If nothing happens then either the power has shutoff as mentioned above or controller is faulty.
Depending on your familiarity with such equipment you could try to replace and fix. I am not quite sure what the new model you mention is. I believe all DD603 models have power to the 2 drawers coming from the base board.
DD24DCX7 Dishwasher - Top Drawer Not Working
Hi Brendan,The dishwasher will stop mid cycle if the door is not closed properly, please ensure that the door is shut firmly and the latch engages fully.Also a broken door latch, faulty control panel or failed electronic control board could be causing the problem.Hope this helps.Best,Dan
