20 Most Recent
Fisher and Paykel 24 in. DS-603 Built-in Dishwasher Questions & Answers
Fisher and paykel dishdrawer draw stuck after beeping
Maybe the sealing thing is stuck in the down position? It rests inside the rim of the drawer when it's operating...
Maybe the buttons are locked (this is a feature). Mine has a button with a lock symbol. Hold it down, and then maybe your buttons will work again?
The 06h indicates the unit is in delayed wash mode. Weird.
DISH DRAWER WILL NOT EMPTY PROPERLY
check the hose is not kinked that lets the waste water out. otherwise change the rotor at the bottom of the drawer. this can be accessed by unscrewing the panel at the bottom of the drawer to reveal the rotor. lift it out and place the new one in. replace the covers. try again.
Dishdrawer stops beeps mid cycle
It could have fogged up because you had the drawer cover off in the first place.
The problem may be the alignment of the mirrors. If the control board has slipped down so that the mirrors do not line up to the photo cell and led---that can cause the problem you are having. Make sure the mirrors (light tubes) are properly lined up with the photo cell and led on the control board. You may have to move the control board to make this alignment. Once aligned secure the board in place and this should solve your problem. NOTE: MAKE SURE THE POWER IS TURNED OFF BEFORE YOU MAKE THIS REPAIR.
Why does our dishdrawer tripout the safety switch in the fuse box?we have tried different electrical outlets in the house same result?
https://www.fisherpaykel.com/nz/support/user-manuals/
Fisher & PaykelFind and Download User Guides and Installations Manuals for your Fisher & PaykelAppliances: ... This will help getting a quicker and more accurate result.
https://www.fisherpaykel.com/au/support/expert-tips/
Fisher & PaykelExpert Tips. Select a product type to see solutions to most common problems you may encounter with your appliance. Search. -Select-, Built In Ovens, Electric ...
https://www.fisherpaykel.com/.../590199D%20
DishDraw...
Fisher & Paykelguide', you can download it from our local website, listed on the back cover. Refer to ...Preference options and how to change their settings ... standard safety regulations.Fuse cover. Fuse. Electrical connection (GB IE only) ... Do not use an extension cord or a portable electrical outlet device (e.g. multi-socket outlet box).
12/25/2015 11:42:29 PM •
Fisher and...
Answered
on Dec 25, 2015
Ds603 flood switch has been activated
The flood switch is at base of dishwasher housing under the drawer. Water leakage has occured to trigger this. Turn power off to dishwasher and take the power chord out. Pull the drawer out and use towels and hair dryer to dry the base. Put drawer back in and reconnect. Should work. Need to find the cause of leak. Either damaged lid seal or leaky hoses. Sometimes too much foam in detergent can cause it. Use recommended detergent and appropriate quantity per user manual.
Beep continuos and cycle stops
Water flood in the base of dishwasher. Check the fault code lights. If F1 then this confirms the problem. Need to find the source of leak.
Water will not empty and beeping will not stop on
The flood switch has turned on. There is a leak into the base of the housing. Turn mains power off. Open bottom drawer and dry the base using towels etc. Need to find the source of leak. Lid seal or hoses.
Dishdrawer door comes ajar
It is also likely the drawer has come off the gliding rail at the right.
You will have to pull the drawer out from the housing and check. Not sure if you have a standalone unit or integrated with the kitchen cupboard. The instructions to pull drawer out are available in the installation manual. Select the correct model from this site .
http://www.fisherpaykel.com/au/support/user-manuals/
Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
