20 Most Recent Denon AVR-883 Receiver Questions & Answers
I was re-wiring my surround speakers to my Denon
A shorted wire would do it. Take it to a tech and tell him what happened. If you remember which channel you were handling at the time it might help hum to find the problem.
12/24/2010 12:42:17 AM • Denon AVR-883... • Answered on Dec 24, 2010
My denon avr 1803/883 shut off while playing a cd
CHECK IC101 AND IC102 THESE ARE THE + AND - 15VOLT REGULATORS. iF THEY ARE OFF BY MORE THEN 3 VOLTS IT WILL SHUT THE UNIT DOWN/IC101 IS THE +15V AND IC102 IS THE -15V IF THESE VOLTAGES ARE GOOD THEN THE UNIT IS GOING IN TO THE PROTECT MODE AND YOU WILL HAVE SHORTED OUTPUT TRANSISTORS. I HOPE THIS HELPS YOU.
4/19/2010 10:29:56 PM • Denon AVR-883... • Answered on Apr 19, 2010
Denon AVR 883 no sound from any source including zone 2 speakers
This sounds like a thermal issue, meaning after the receiver has been on for a while it gets to warm and then fails. I suspect after 8 years the unit may have accumulated some dust that is not allowing the heat sinks to dissipate heat adequately. I would use compressed air and blow the unit out. Some computer stores have blow stuff in a can that work well. If you have and air compressor, dial it back to 10 psi or so. You will be amazed at how much dust will come out of that unit so you may want to unhook the unit and take it outside. Also be careful not to stack anything on top of your receiver. Make sure there are lots of openings around the unit. High temperatures kill electronics.
Hope this helps.
4/3/2010 2:41:03 PM • Denon AVR-883... • Answered on Apr 03, 2010
Denon AVR 883 Audio glitch
More than likely the protector circuit is getting activated... You can't go below 6 ohms on the surround back which means you need 12 ohm or higher speakers for outside (since the two outputs for surround back/zone2 are in parallel). As a simple diagnostic test, disconnect one speaker and see if the sound survives longer than 2 seconds.
4/4/2009 6:36:47 PM • Denon AVR-883... • Answered on Apr 04, 2009
0answers
Size of fuse for Denon dra 697
The Denon DRA-697CI stereo receiver typically uses a 250V, 2.5A fuse. However, it's always a good idea to consult the user manual or check the label near the power input on the device itself to confirm the exact fuse size and specifications for your particular model. Using the correct fuse size is important for safety and to prevent damage to the receiver. If you're unsure, you can also contact Denon customer support for assistance.
2/24/2024 6:30:15 PM • Denon Audio... • Answered on Feb 24, 2024
Fuse size for Denon DRA 697 c!
The Denon DRA-697CI is a stereo receiver. Typically, the fuse size for electronic devices like stereo receivers is listed in the device's manual or on a label near the power input. It's important to use the correct fuse size to ensure proper protection against electrical faults. Without specific information about the fuse size for the Denon DRA-697CI, I recommend consulting the device's manual or contacting Denon's customer support for accurate information. Using the wrong fuse size can potentially damage the device or pose a safety hazard, so it's crucial to verify the correct specifications.
2/24/2024 6:29:09 PM • Denon Audio... • Answered on Feb 24, 2024
I have a old Denon DP-47F turntable, if I pressed the Arm lifter button, the tonearm can be slowly rising, but if Down, the tonearm will suddenly go down, no buffering. Please ask how to fix it.
Check and clean the dampening piston(s) associated with the raise / lower mechanism. The silicon oil may have dried up or leaked out.
2/8/2024 5:55:06 PM • Denon Audio... • Answered on Feb 08, 2024
Denon avr 5805 starts up and emeadatly shuts doun
More than likely the mosfets are shorted in the output stage.
2/8/2024 5:51:11 PM • Denon Audio... • Answered on Feb 08, 2024
Need a BU9000 replacement drive for Denon DN-D9000 dual cd deck
https://instrumentalparts.com/denon-dnd9000-traverse-unit-w-laser-sled-disc-motors/ I think they are now obsolete but the laser assembly and motor, (the only parts that fail) are still available.
1/20/2024 1:35:13 PM • Denon Audio... • Answered on Jan 20, 2024
Denon AVR 1509. How to unlock the panel lock please?
Question edited for a lot more clarity and add maker. Question moved from Cars and Trucks category.
Denon AVR Panel lock function
Denon https://support.denon.com > answers > detail > a_id Yes. All our newer AVRs have a procedure to lock out the front panel to keep accidental button presses from occurring. This is a push button procedure and ...
Canceling the Panel lock function AVR-S640H
Denon https://manuals.denon.com > SEHFSYojjpdajr Canceling the Panel lock function · Press Power Button while you press and hold TUNER PRESET CH + and TUNE + with the unit in standby mode. · Press TUNE + or TUNE ... People also ask How do you unlock the panel on a Denon receiver?"); display: inline-block; height: 24px; width: 24px;"> How do I reset my Denon AVR 1509?"); display: inline-block; height: 24px; width: 24px;"> How do I turn off the panel lock on my Denon AVR s540bt?"); display: inline-block; height: 24px; width: 24px;"> Feedback
Panel lock function NR1509
Marantz https://manuals.marantz.com > SEHFSYeumlhqks Panel lock function ... To prevent accidental operation of this unit, you can disable operation of the buttons on the front panel. Open Front Key Lock N59. Basic. ..
11/25/2023 5:39:10 AM • Denon Audio... • Answered on Nov 25, 2023
What's wrong with my denon avr1601
The best thing would be to check all the connections, and if everything is in order and tight and still not working properly, then you'll need to notify Denon customer support for further assistance
8/29/2023 8:22:49 PM • Denon Audio... • Answered on Aug 29, 2023
Denon dvd 1940 problem. All funcion is ok, but audio impul not works? but
Check all connections from the DVD player to your amplifier/receiver and TV. Make sure the audio cables are securely connected at both ends. Try connecting the DVD player to another amplifier/audio system using different cables to isolate if the issue is with the player or cables. Check the audio settings on the DVD player - make sure audio output is enabled and set to an appropriate format like PCM or Bitstream. Go through the audio setup menu and reset to factory defaults. Make sure the volume on the DVD player is turned up and not muted/very low. Try different audio tracks on a DVD movie to test. If connected digitally via HDMI, try swapping to analog RCA connections instead. Or vice versa. Try playing audio CDs to see if the issue only affects DVD movies or all audio. Make sure the audio on the disks themselves are okay by testing in another player. If there was a power surge or electrical issue, the audio circuits could have been damaged. A repair service may be needed. As a last resort, perform a factory reset or firmware update on the DVD player.
8/27/2023 12:40:15 PM • Denon Audio... • Answered on Aug 27, 2023
Is it possible to add a sumo amp to a Denon AVR
Yes, it is possible to add a Sumo amplifier to a Denon AVR (Audio/Video Receiver) system. The Denon AVR is designed to be the central hub for audio and video processing, providing amplification and routing signals to speakers and other audio devices. To add a Sumo amplifier to your Denon AVR system, you can follow these general steps: 1. Determine the audio output options on your Denon AVR: Check if your Denon AVR has preamp outputs, which are typically labeled as "Pre Out" or "Main Out." These outputs are used to connect external amplifiers like the Sumo amp. 2. Identify the input options on the Sumo amplifier: Check the inputs available on the Sumo amplifier. It should have an input that matches the output from your Denon AVR. The most common connection is RCA, but there could be other options like XLR or optical. 3. Connect the Denon AVR to the Sumo amplifier: Use appropriate cables to connect the preamp outputs of your Denon AVR to the inputs of the Sumo amplifier. For RCA connections, you will need RCA cables with male connectors on both ends. Make sure to match the left and right channels correctly. 4. Configure the Denon AVR: Once the connections are made, you may need to configure the Denon AVR to use the external amplifier. Check your Denon AVR's manual or menu settings to disable the internal amplifier for the connected speakers. This will ensure that the AVR sends the audio signal to the Sumo amp instead. 5. Set up the Sumo amplifier: Follow the instructions provided with the Sumo amplifier to set it up correctly. This may involve adjusting gain levels, selecting input sources, and configuring any other settings specific to the Sumo amp. 6. Test and enjoy: Once everything is connected and configured, test the system by playing audio through your Denon AVR. The audio signal should be amplified by the Sumo amplifier and sent to your speakers, providing enhanced power and performance. It's worth noting that the specific steps and options may vary depending on the models of your Denon AVR and Sumo amplifier. It's always recommended to consult the user manuals for both devices and, if needed, seek assistance from an audio professional or the manufacturers' support teams for detailed guidance tailored to your specific equipment. This MIGHT help a little
6/21/2023 1:13:53 AM • Denon Audio... • Answered on Jun 21, 2023
How do I add a 2 channel amp to a Denon avr 2307ci
To add a 2-channel amplifier to your Denon AVR 2307ci receiver, you can follow these general steps: 1. Determine the amplifier connection type: Check the specifications of your 2-channel amplifier and identify the available input and output options. Common connection types include RCA (analog) and speaker wire (for binding posts or terminals). 2. Identify the pre-out connections on your Denon AVR: Locate the pre-out connections on the back of your Denon AVR 2307ci receiver. These are typically labeled as "Pre Out" or "Preamp Out" and may be color-coded. You will need to find the pre-out connections for the front left and right channels. 3. Connect the RCA cables: If your amplifier has RCA inputs, use RCA cables to connect the pre-out connections of the Denon AVR to the corresponding inputs on the amplifier. Connect the left channel pre-out on the Denon to the left channel input on the amplifier, and do the same for the right channel. 4. Connect the speaker wires: If your amplifier uses speaker wire connections, connect the front left and right speaker outputs of the Denon AVR to the corresponding inputs on the amplifier using speaker wire. Make sure to observe the proper polarity (positive and negative) when connecting the wires. 5. Configure the Denon AVR settings: Access the setup menu of the Denon AVR by using the remote control or the front panel display. Navigate to the audio settings or speaker configuration section. Look for an option to enable "Preamp Mode" or "Preamp Outputs." Enable this option to ensure that the front left and right channels are redirected to the pre-out connections. 6. Set the amplifier to the correct input: If your amplifier has multiple inputs, select the input that corresponds to the connection from the Denon AVR. 7. Adjust volume and settings: After completing the connections, you may need to adjust the volume levels on both the Denon AVR and the amplifier. Use the Denon AVR as the primary volume control and adjust the amplifier's volume accordingly. It's important to consult the user manuals for both your Denon AVR 2307ci and the 2-channel amplifier to ensure proper setup and compatibility. If you're uncertain about any specific steps or settings, it's advisable to consult the manuals or reach out to Denon customer support for assistance. This video MIGHT help a little
6/21/2023 1:11:03 AM • Denon Audio... • Answered on Jun 21, 2023
Need a wiring diagram for a Denon AVR 2307ci
6/21/2023 1:07:23 AM • Denon Audio... • Answered on Jun 21, 2023
Denon AVR-883 Receiver Logo
10 questions posted
Popular Products
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Denon Audio Players & Recorders
Most Popular Question
re wiring surround speakers denon
  • Audio Players & Recorders
