20 Most Recent
Samsung Tracfone Sgh T105g Cell Phone Black only Cell Phone Questions & Answers
My phone says unregistered sim
When it says unregistered SIM that clearly indicates that the SIM you are inserting is not active from the service provider. There could be various reasons for the same which can only be clarified by calling the Service provider of your SIM.
I try to call my safe link phone says check call restrictions 34,how to I fix this!
Did you make at least one call per month on the tracfone? If not this maybe one of the reasons the call is restricted. You may have to manually receive your minutes for the month by: Pressing the menu key, when the prepaid menu appears press select. Go to redeem airtime or add airtime. If your screen displays a message scroll down and press ok until you see Card# or Airtime Pin. Enter 555 then press enter. If it says promotional code select no. Make sure you keep your safe link phone on to receive your minutes and see if that fix the problem. If that doesn't work you may have to call safe link at 1-800-378-1684.
Best Regards!
What can I do to get dialed numbers from my tracfone that no longer work?
It is highly doubtful that you will be able to retrieve anything from your phone. Once the electronics are shorted out by water with the battery installed all data and circuitry become unaccessible in almost all cases. You might try your cellular carrier, but once again the chances are next to nothing.
How do I download a manual for Samsung T105G?
To download a manual type in your browser manual for Samsung t105g, you should be able to prprig it. To space on your tracfone you press on the right side of big square bar in the middle and press to the left side to back space. Hope this helps!
I forgot my puk code
PUK code is regarding the SIM . So contact your customer care and get your puk when u enter the puk the new pin will be asked where you can give your new pin as you like
Regards,
[email protected]
Tracfone tutorial
The voicemail is on the computer at your carrier's office, not on your phone. Call ATT or Verizon (or whoever your carrier is) and ask them to reset your password - then log in, listen to voicemails and change your message from there. If the phone is old and no longer connected to a carrier, the messages are lost unless your new phone uses the same carrier (you should be able to log in with your new phone and listen to old messages if you did not delete them yet - even if they came in when you owned this old phone.
Tracfone customer service
you must contact the customer service for the phone and tell them you want to activate the phone that you already have and they will have to send you a new sim card. You will not be able to activate the phone unless you get the sim card from them. Your service time would have expired but if you purchased double airtime minutes for life you will still have that honored. You will have to purchase more airtime in order to have more service days.
