20 Most Recent
Denon AVR-3600 Questions & Answers
Can a Denon 3600 be updated to except wyfi
I think you'll be fine, as this particular receiver's video connections allow for 4K.
Connections:
- 1080p-compatible HDMI digital audio/video switching; 6 in (including 1 front-panel input), 1 out
- HDMI version 1.4a with support for 3D video, 4K video, Audio Return Channel, Deep Color, x.v.Color, auto lip-sync, and HDMI-CEC
- analog-to-HDMI video conversion to 1080p
- HDMI-to-HDMI video conversion to 4K Ultra HD
The sound level drops
Try turning off Dynamic range controls and any other setting that manages volume levels. My Yamaha RX-A3020 had a similar issue.
Some weeks ago the sub
Hi, I went to the Denon website and they have no documentation there for your receiver.
But do not frown, I have some good suggestions for you.
0 Don't beat the dog. After all, it's their job to chew things.
1 Get a new, un-chewed cable and see what happens between the sub output and the sub woofer. If it works, your in business. If it does not work. Don't be discouraged . Go to step #2
2 If the sub output on the Denon has failed, and everything else is good. There is another way to use your sub.
Install a patch system using the Headphone output from the front of the Denon. It may seem odd, but it works exceptionally well for the following reasons. It works on all signal sources. So if you are not playing a home theater source, you still have the use of your sub.
You will need the following adapters.
1 A Male stereo phone jack to female mini-phone jack. (Something that would accept typical small headphone sets such as those on an iphone).
2 A stereo "Y" connector that that has a single stereo male mini-phone jack that has two "RCA" female jacks.
3 A simple RCA male to male stereo cable pair as is commonly used to connect CD players, etc. i.e. separate red and white RCA connectors at both ends.
1 and 2 above may be available as a single unit combined with each other.
Take these adapters and connect the Item 1 into the Receiver, Item 2 plugged into Item 1, Item 3 plugged into Item 2 and finally the other end of Item 3 plugged into the two female RCA jacks mounted onto the back of the sub-woofer. If the sub only has one female RCA connector, get a RCA "Y" connector that has a single male end to 2 female ends.
This setup will work perfectly with any sub. The reason is as follows. Most decent subs have an adjustable high frequency cut off. So you can vary it from about 20Hz up to about 140 Hz.
I recommend that it is cut off at 80 hz. This way the bass transition is usually seamless between the woofer and the rest of the system. .
Then adjust the woofer volume control in a similar manner.
If it all works out, give the dog a treat and enjoy yourself.
I really hope this helps, I love my sub woofer as well.
Let me know how this turns out.
If you have any questions please post them on the site and I'll get back to you ASAP.
Best Regards,
Mark
Protection mode
The protect mode with nothing connected indicates that the output transistors for one or more channels are shorted. These will need to be checked and replaced. This is a simple repair for an experienced audio shop, Figure about $10 for each output transistor and add in another $10-$15 for misc parts that may also be smoked.
Dan
My 3600's center Channel is cracking when I plug a center
try connecting it to the right speaker or left to see if it cracks through there. if not, you may have a center ch terminal problem. if so, make sure you have a good connection at the speaker and terminal. make sure you dont have any strands of speker wire touching the chasis.
Denon AVR 3600 sound gone
this happened to me once and I found that my reciever would just shut down. make sure that you have plenty of space above the amp. it may be over heating and shutting down on you and when it cools down, it turns back on. there will most likely the "overload" light will be lit when it shuts down the audio.
hope that helps
Denon AVR-3600, Sound issue on one side only
sounds like you may have a bad tweeter in your speaker. change the right and left speakers and see if the problem persists in that same speaker. if so, you have a bad speaker.
