20 Most Recent
Beverage-Air Kegerator - Beer Keg Cooler Refrigerators DD48 2 Keg Space Saver by Beverage Air Questions & Answers
Litres to a gallon
One US gallon is about 3.785 litres. One UK gallon is about 4.546 litres.
Beverage-Air Kegerator Not Staying Cold
It can take a very long time to get a keg of beer down in temperature. The heat transfer from a keg is slow due to the lack of air circulation inside the keg. You should also check your condenser coils, make sure they are clean. Door gasket should also be in good repair. Hope this helps.
I have a beverage air kegerator that seems to work
Most evaporator fans run all the time. This is mainly to use the air flow to assist in melting off any frost build up during the compressor off cycle. If that fan shut off with the compressor the coil will have a tendency to freeze up. :)
I have a question
It sounds like you have a bad fan motor. Call a service company out. They should be able to fix it. :)
Have not used the kegerator
Check to see if any of the compressor electrical items came loose when moving.
I had this happen to a customer and he called someone else in who tried to sell him a new compressor.
