20 Most Recent
LG BP-520 3-D Region Free DVD and Region A BRay Player Questions & Answers
How to make LG BP520 region free?
DVD REGION FREE & BLUE-RAY REGION FREE To change the Region code on your DVD player, open Control Panel - System - Hardware - Device manager, and click on DVD/CD ROM drives, then right click on the DVD drive and click Properties then click on DVD Region. You can enter a new region and it also shows you how many changes have been made. NOTE you can make only 4 changes and the player will lock permanently on the 4th change. If you want to play DVDs from any region you maybe able to upgrade the firmware to make it region free BUT if you make a mistake or installed the wrong firmware the player will be a piece of junk. The best solution to make the player region free is to install a piece of software (Passkey for DVD) that allows you to play DVDs from any region and Passkey for Blu-ray that allows you to play Blu-rays from any region. There are several available on the Internet but my favourite is DVD-Region Free From: -
www.dvdfab.com/products,free.htm
Cannot play avatar in 3d
What type of graphics card you might only need to update the drivers to 3D drivers
http://ati-catalyst-drivers.en.softonic.com/ Optimise your ATi graphics card's performanceWhich operating system ?Click start right click on computer select properties device manager scroll to cd dvd drives expand right click select update driver software windows 7 will automatically search for a find the updated software.
Click start control panel administrive tools, computer management, device manager scroll down cd-dvd rom drives
Cd/dvd firmware
http://www.cdrinfo.com/Sections/Firmware/Home.aspxyou might find something here you will need to select make manufacturer and model
What normally burns out the LG Hi-Fi Amplifier?
Full 'make model (what it is)' in all questions please, first 3 words.
Capacitors can split or bulge, resistors can burn,, the transformer can fail internally..
Take it for repair unless you have the thousands of dollars of test equipment and have do the 2 year electronic course.
What does 9 red flashes mean on LG multi V LMU540HV
A communication error has occurred between the outdoor and indoor units. Faulty wiring or a malfunctioning control unit may be responsible. Contact LG customer service for assistance. Their number is 1 800 243 0000.
How to sync TCL ROKU TV to LG sound bar
You will need to connect a single HDMI cable from your sound bar to the HDMI ARC or the HDMI eARC port on the Roku T.Make sure that both of the devices are both turned on.When your TV detects the sound bar,it will then automatically initiate the setting up process. Lastly follow the easy on screen instructions to finish setting up the connection.
LG 55UM7300PUA not powering on
If your LG 55UM7300PUA is not powering on, there are a few things you can try to troubleshoot the issue. 1. Check the power cord and make sure it is securely connected to the TV and to the wall outlet. 2. Check the wall outlet to make sure it is working properly. Try plugging in a different device to the outlet to make sure it is providing power. 3. Check the power button
