20 Most Recent
Aspire Digital AD-900 DVD Player Questions & Answers
ASPIRE only playing in Black & White
This is a bad connector. Replace the ends or the cable. If that does not cure it try wiggling the cable at the console itself. Could be the connector on the tv.
Aspire Digital AD-N820B DVD-R stuck in Progressive Scan ( PSCAN )
I just had the same problem with the same model but I was able to figure it out after a while.
From the remote control:
SETUP
Scroll left or right to the PREFERNCES menu.
Scroll down to the bottom until DEFAULT is highlighted.
HIt the PLAY button in the remote while RESTORE or RESET is highlighted.
The DVD player was reset back to factory settings within 10 seconds.
Dvd player not showing color
you are only having porblem with your color system. if you are using a multi system DVD player then see if it is properly selected to your region. in USA it should be NTSC 3.59, if you're in Europe it should be PAL. if you're using your DVD via a DSP or audio systems, check also the color system of the amplifier, it should be adjusted to your color system.
Installing or connecting my dvd player to my television
if you're using a simple connection, connect the yellow colored output connection of your DVD to the video input of your TV. The audio out of the DVD red and white will go to the red/white of the TV also. If your TV is one channel or monaural, then you can only connect either the red or white.
you can also makje the connections in stereo if you are using a DSP amplifier. in that case your DSP should also have a video input and that is where you will connect your DVD. The video output of your DSP will go to the TV input. Just remember the color, Yellow is video signal )composite) and Red/White for left and right chanel audio.
All of a sudden the
Check the connections between the DVD player and the TV. If using RCA cables, replace them, as one may be defective. If using S-video, check its connection is secure. It is probably just a bad cable connection or in the case of the standard yellow-white-red RCA, this is probably defective at its sealed plug points - replace this.
If checking/replacing cables does not fix the issue, the DVD player and/or TV may require workshop attention, which could prove costly. I hope it's just something simple, like bad cables/connections.
How to remove child lock from BELTEK TV?
general steps:
Get the TV remote control and push the "Menu" button and select "Options".
Select "Child Lock" from the "Options" list. On some televisions, the "Child Lock" is named "V-chip".
Choose the "Remove Child Lock" selection. Highlight this and then hit the "Enter" button.
Enter the four-digit code that you used when you activated the child lock feature. If you cannot remember it, your only option to deactivate the child lock is to reset the TV. The instructions for resetting a TV is written on the user's manual of the TV.
Exit the TV menu once you have entered the four-digit code. To do this, press the "Exit" or "Menu" button on the TV's remote control.
If you don't have a remote, you might try leaving the TV unplugged overnight. Some TVs will 'forget' their settings if left without power for a long period. You could also potentially buy a cheaper universal remote, and use that to turn off the child lock.
How to pairing Ruwido Amadeus R 9710 to tv?
To pair your Ruwido Amadeus R 9710 remote to your TV, you can follow these steps:
Insert Batteries: Your remote is powered by two 1.5 V AAA batteries1. Make sure to insert the batteries correctly.
Switch on your TV: Ensure your TV is turned on.
Press the TV key: Press the TV key on your remote control for approximately 4 seconds until the LED flashes twice.
Enter the Code: After seeing the 2 flashes and within 5 seconds, enter the 3-digit numerical code from the list provided with your remote2. After entering the code, the LED will flash twice indicating that the code has been accepted.
Test the Remote: Point the remote control towards your TV and press the key. If your TV does not respond by going into Stand-By mode then repeat steps 3 to 5 and enter the next code in the list.
Bed.-Anl. H2 Version1 (ruwido.com)
