20 Most Recent Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs Questions & Answers
After harvestering it take 10 mins. to kick back into freeze again
Replace the ice thickness control hanging on front of the evaporator plate
8/15/2014 6:37:43 PM • Scotsman Cooled... • Answered on Aug 15, 2014
Water keeps running
where is the water running on the ice head or is this a remote water cooled condenser? If water is running all the time at the ice head into the sump tray and overflowing into the ice bin then check the water inlet valve ether rebuild or replace valve but make sure the water low sensor is not calling for water when the sump tray is full of water.
7/25/2014 7:22:21 PM • Scotsman Cooled... • Answered on Jul 25, 2014
Bin full light stays on
You need to pull the bin full sensors and clean or replace them. Pull the front cover off remove the ice deflector you will see the water sump tray pull the ice deflector grate out of sump. Now where the ice fall into the bin on the right and left side in the shout there is 2 sensors they will pull out sideways, they will both have a wire ran to them pull wire and sensor up to where you can see the red sensors om them take a descale solution Scotsman brand mix per instructions and clean the eyes now would be a good time to clean and disinfect the whole machine. Install them back and start machine if this dose not clear the bin full light then replace them.
7/25/2014 7:13:33 PM • Scotsman Cooled... • Answered on Jul 25, 2014
I have a scotsman cme250 ice machine that the
Yes replace the timer
7/7/2014 5:08:35 PM • Scotsman Cooled... • Answered on Jul 07, 2014
2answers
Scotsman cme506
i service scotmen cme506 blink 2 times in the water iclean bin sensors check water lebels install new inlet valve and due same
4/20/2012 10:23:48 PM • Scotsman Cooled... • Answered on Apr 20, 2012
Scotsman icemachine cm506 stuck in
check for power to valve coil. If it remains it's a control problem. If no power and still in harvest, valve is stuck. Unit usually does not exceed a 6 to 8 minute harvest.
1/21/2011 4:06:41 AM • Scotsman Cooled... • Answered on Jan 21, 2011
Scotsman CME250 ice machine, compressor will only
The thermostat energizes the contactor. If it is bad, thus you problem.
1/17/2010 7:49:03 AM • Scotsman Cooled... • Answered on Jan 17, 2010
Scotsman n1322 remote cooled ice machine
either there is a call for cooling from the bin thermostat or the condenser needs to be cleaned. Check the gaskets to make sure they are not cracked or torn.
1/17/2010 12:38:32 AM • Scotsman Cooled... • Answered on Jan 17, 2010
Unit turns off on ref code
Is it making the proper size cubes?
2/10/2009 2:27:30 AM • Scotsman Cooled... • Answered on Feb 10, 2009
Water keeps running
Check for trash in the water valve. Insure the water lines don't have rust flakes in them. The water valve is operated by the float arm. Anything in the water line can keep the valve stuck open and stop production of ice. Hope this helps, Sea Breeze
10/28/2007 6:25:10 PM • Scotsman Cooled... • Answered on Oct 28, 2007
Light on too hi evap temp on scotsman 80 ice machine
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.scotsman-ice.com/service/Diagnostic%20Aids/Diagnostic%20Aid%20CU0415.pdf This will help you do a diagnostic check of the thermistors
4/18/2024 7:28:41 PM • Scotsman Kitchen... • Answered on Apr 18, 2024
SCOTSMAN AC 126 AS/WS - Ice Machine (Gourmet ice). The one I am using in my work place, after 1st cycle, red light blinking continuously. Please share how to solve the issue?
Question edited for clarity. Clean, defrost, descale, reset it. These machines need maintenance.
service manual
Bla?ek gastro, s.r.o. https://www.blazekgastro.cz > files > ac106_12... Located on the front left side of the machine, it works in conjuction with the condenser sensor and the Red Alarm Re?set Push Button. It consists of a Printed Circuit... Service Manual https://www.blazekgastro.cz/files/ac106_126_176_206.pdf Owner Manual
Scotsman AC 126 Manuals
ManualsLib https://www.manualslib.com > ... > Ice Maker Manuals and User Guides for Scotsman AC 126. We have 1 Scotsman AC 126 manual available for free PDF download: Service Manual ; General Information and ... ..
10/5/2023 12:18:31 AM • Scotsman Kitchen... • Answered on Oct 05, 2023
Scotsman C0322 Ice Machine not dumping ice. Error code 2
There are a couple of reasons I can think of. One is that the water is running away for some reason and being replaced with ambient mains water.. The other possibility is that the unit is marginally low on refrigerant gas. Another though is that the condenser fins are blocked, this causes general overheating of the compressor and the gas temperature in general. It is a commercial machine and should be professionally serviced at least every 12 months. At my last position, all of ours were serviced every 6 months under contract to keep them in tip top condition. The environment was airport business class lounges and you can't afford to have no ice. I have endured a 50 year career fighting refrigeration appliances. Help here https://www.google.com/search?q=Scotsman+C0322+Ice+Machine%2C+error+code+2 ..
6/16/2023 2:09:29 AM • Scotsman Kitchen... • Answered on Jun 16, 2023
Why is my Scotsman n0422a the water and ice icon button is flashing red why?
Disconnect the power at the wall for 5 minutes. It resets the control board.
4/4/2023 2:27:51 AM • Scotsman Kitchen... • Answered on Apr 04, 2023
Scotsman cm3 656 water will run but will not harvest unless I push the harvest button. Water will continue to run unless I turn it off. Could this be a bad well pump or a water level sensor gone bad?
If your Scotsman CM3 656 ice machine is not harvesting ice automatically and water continues to run unless you turn it off, there could be several possible causes. Here are a few things you can check:
  1. Check the water level sensor: The water level sensor is responsible for detecting the level of water in the sump and controlling the fill and harvest cycles. If the sensor is faulty, it could cause the ice machine to not harvest ice automatically. Check the sensor for any damage or debris, and clean or replace it if necessary.
  2. Check the water inlet valve: The water inlet valve controls the flow of water into the ice machine. If the valve is stuck open, it could cause water to continue to run into the machine. Check the valve for any damage or debris, and replace it if necessary.
  3. Check the temperature sensors: The ice machine has temperature sensors that monitor the temperature of the evaporator plate and control the harvest cycle. If the sensors are faulty, it could cause the machine to not harvest ice automatically. Check the sensors for any damage or debris, and replace them if necessary.
  4. Check the control board: The control board is the brain of the ice machine and controls all of its functions. If the board is faulty, it could cause the machine to not harvest ice automatically or to continue to run water. Check the board for any damage or corrosion, and replace it if necessary.
It is unlikely that a bad well pump would cause these symptoms, as the water is still running into the machine. However, if you suspect there is an issue with your water supply, you should check your water pressure and flow rate to make sure they are within the manufacturer's recommended specifications.
3/17/2023 8:01:27 PM • Scotsman Kitchen... • Answered on Mar 17, 2023
New and Newly installed Scotsman UC2024 under counter ice machine seems to work fine all day then turns off overnight. Having to unplug and replug for it to start again. Please help.
They turn off when the hopper registers as full. It should restart as ice is taken away. By power resetting it, you are forcing it back to life. Presumably, shortly after that, you remove ice so it does need to be running then?
3/13/2023 5:10:41 PM • Scotsman Kitchen... • Answered on Mar 13, 2023
My Scotsman SCCG30 won’t go into Harvest cycle. If I turn it off and turn it back on, it Harvests and then goes back to freeze cycle but still will not harvest.
Without more information it is hard to be precise. You can try the following:
  1. Clean the machine, including vacuuming the condensor coil (below) and running the cleaner through the water circulation system.
  2. Check functions which includes 1) fills the reservoir with adequate water, 2) cools the mold (water gets cold) and sprays water up into molds, 3) are both spray caps on and is the water spraying in a fine, circular pattern, 4) is the curtain intact and not allowing water to leak out of the reservoir and into the storage bin.
  3. If the water is getting cold and if the spray nozzles are working properly then there should be ice in the molds (you can feel with your fingers). Then the pump should shut off and the cooling system goes into harvest cycle. At this point a reversing valve (under the unit) causes the ice making mild to warm. Combined with the fresh water (refilling the reservoir) running over the mold and the warming mold, the cubes should release.
  4. Typical fill, freeze and harvest takes approx. 25-28 minutes.
1/16/2023 3:51:24 PM • Scotsman Kitchen... • Answered on Jan 16, 2023
2answers
Scotsman ice make no water light flashing
If the "no water" light on your Scotsman ice maker is flashing, it means that the ice maker is not receiving a sufficient supply of water. There could be a few possible causes for this issue. Here are a few things you could try:
  1. Check the water supply. Make sure that the water supply valve is turned on and that there is sufficient water pressure.
  2. Check the water inlet valve. The water inlet valve is responsible for letting water into the ice maker. If the valve is faulty or clogged, it may not be allowing enough water to flow into the ice maker.
  3. Check the water line. Make sure that the water line is not kinked or clogged.
  4. Check the water pump. If the water pump is not working properly, it may not be delivering enough water to the ice maker.
If these steps do not help, there may be a problem with the ice maker itself. In this case, you may need to have the ice maker repaired or replaced.
1/7/2023 9:04:51 AM • Scotsman Kitchen... • Answered on Jan 07, 2023
Scotsman Cooled Modular Contour Cuber Remote Condensed 425lbs Logo
15 questions posted
Top Scotsman Kitchen Appliances - Others Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Sierra
Sierra
Level 1 Expert
Are you a Scotsman Kitchen Appliances - Other Expert? Answer questions, earn points and help others
View Most Popular
  • Scotsman Kitchen Appliances - Others
Most Popular Question
scotsman cme250 ice machine compressor
  • Kitchen Appliances - Others
