20 Most Recent
Cavs JB199-160GB Karaoke jukebox & Digital Recording. Build-in 160GB hard Drive. Questions & Answers
Can I restore the machine, JB-199 Karaoke machine,
Welcome to Fixya
Try this procedure. Restoring the player will put back everything to the original state and that would mean deleting all the list that you created. You may try to reset the machine by pushing the small reet hole located at the back of the machine by using a needle or paper clip.
- Turn on your player w/o a disc
- Wait until the front displays says "no disc"
- press SETUP
- press UP ARROW 2 times (to Preferences)
- press ENTER
- press UP ARROW 3 times (to Defaults)
- and RIGHT ARROW once (to Reset)
- then press ENTER.
- Restart your player.
COMPLETELY RESET UNIT
- Make sure that there is no disc in the tray.
- When you see no disc sign, press Setup once.
- Press down arrow 4 times and press Enter once.
- Press down arrow 5 times and right arrow once.
- Press Enter once and Setup once.
Thank yuo for using Fixya! If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
No video on the tv.
make sure u got the rite plugs 4 the unit 2 work check the inputs an out puts 2 c if u r color rite. audio is red white blue green black there r differnt ones make sure u rite
Jb199 doesnt display welcome page,I push the power..
Pull cover off box and remove battery (small toward the front of the machine) This will reset the Bios.. after that when restarting go into the bios by pressing the "Delete" Key and hit load failsafe bios. this should fix everything.
JB199 karaoke machine
Try hooking your cavs up with a keyboard and a mouse get your desk top up and you will notice new updated . udated and it will work again. make sure you register song files after u up load
Jb 199
Need help with CAVS JB199 I recommend calling Bob at CAVS EAST. He's very fast and a whole lot better than talking to the ones at the company that you can't understand what there saying. Tel # is 301-876-4535 Tell him Gene sent you
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
