20 Most Recent
Cavs DVD-203G DVD/ SCDG/ CDG (CD+G)/ MPEC-4 Karaoke Player Questions & Answers
Remote wont work
Hi, The first thing to check for is corrosion of the battery terminals. They can become dirty with battery acid that leaks out over a period of extended disuse. ( having remote sit unused for even a few months may cause this. You can visually check for the corrosion-the battery terminal/s will have a whitish or greenish substance on it/them. A paring knife may be used to scrape the terminals clean, if one of the contaminated terminals happens to be a spring maybe a piece of sandpaper. The corrosion is not as bad as what happens on a car battery-that is it will not immediately eat away at stuff-I do recommend using a napkin to keep the leaked electrolyte off your skin and clothes. Another thing that may cause the remote to quit is if something was spilled on the front of the remote ( unfortunately it doesn't take much and any substance will do it). The Key pad of the remote actually has what are called " FILM RESISTORS " that are on the back of each button of the remote. And any foreign substance can interrupt contact with the circuit board. This can be remedied bay taking the remote apart and cleaning the contacts on the circuit board an the backs of the keypad buttons. To do this there will be screws holding it together, more than likely two to four. They may be located inside the battery compartment. Once screws are removed gentle prying should cause case to snap open, then it's a matter of removing the circuit board-using rubbing alcohol to clean backs of buttons and the contacts on the circuit board,reassembling and hopefully you're back in business. Thanks for choosing FixYa, I hope this was of some help, and good luck-Prodzilla
Dvd password? what is it?
if you bought this dvd player new and you or someone else have not changed the parental password, it should be the default password, something like 0000, 1234 or 4321
While connected via VGA cable
It was pretty tricky without instructions but trial & error brought me to a successful resolution. This machine comes from the factory set to connect directly to a television with supplied RCA cable. Do that before you connect to a VGA monitor. Using the remote control, press setup and then go into "preferences" and look around for "video" and then to "VGA". Once you click "VGA" the TV screen goes frighteningly blank. The next obvious step is to hook it to the VGA cable and VGA monitor. If your computer is also hooked up and on to the monitor there is no karaoke picture. Shut off or disconnect computer and presto, there it is. <br>
www.texsax.com
Words "roll" on Screen
sir, where did you purchase your player?i think theres a problem with your COLOR SYSTEM SETTING...the color system(REGION NUMBER) of your player must be mATCh with your tv monitor
...TRY TO set it using remote control of your dvd player...and try diff color system setting....post the result.ty
eg:NTSC
PAL =THESE ARE THE COLOR SYSTEM
SECAM
Jb 199
Need help with CAVS JB199 I recommend calling Bob at CAVS EAST. He's very fast and a whole lot better than talking to the ones at the company that you can't understand what there saying. Tel # is 301-876-4535 Tell him Gene sent you
Openfit Shokz battery replacement?
Question edited for clarity, typo and CAPS.
Question moved from Cars and Trucks category.
Claim on the warranty irrespective of how long you have had them. They charge $180 but they cost them $20 to buy from China. Package them up and send them tracked and ask them to replace the batteries.
How long is the warranty on AfterShokz?
While we hope you never need it, all new Shokz purchased from authorized retailers come with a two-year warranty that begins on your date of purchase.
Jan 11, 2019
https://www.google.com/search?q=Openfit+Shokz+battery+replacement
My roadking rk4000 wont charge. I turn it off to charge it but there is no indicator light at all, any suggestions?
Are you using the charging cables that came with it? That is a type C. Are you securely attaching the charging cable? A loose connection would keep the battery from charging. If you had a low battery, you would see a red light. That you have no light at all suggests there is no charge left in the battery. I'm not sure the reset will work with no charge which is why you ought to check the cables first.
But turn it off and then hold down the Multifunction button for 10 seconds to reset it. Then turn it back on and see what happens. If you can, test the charging cable on aother device. If you have another type C charging cable, try it, just to eliminate a bad cable. If these suggestions don't work, you may try the manufacturer's customer support.
Can f2100 remote work on my dishtv box?
The F2100 remote is not explicitly listed as compatible with the AerialBox T2100, I recommend using the remote that came with your AerialBox T2100 for optimal functionality. If you have any specific compatibility concerns, I suggest reaching out to Dish TV customer support for further assistance.
