20 Most Recent Hoover Nextra HNT 2135 Top Load Washer Questions & Answers
Hoover 500M Top Load washer - Water overflow & machine wont wash
Probably very repairable but impossible to say how much without looking inside and fiddling around and checking a few things. Fault could be caused by several possible faults at widely varying cost. I suggest you call a friendly local white appliance engineer...
2/13/2018 9:34:42 AM • Hoover Nextra... • Answered on Feb 13, 2018
My washer seems to be stuck on a boil wash i turn the knob to another setting and the time light flashers but will not stay on and the washer start a boil wash
Possibly the water level sensor inside is out of order. So, the program only gives the command for filling with water and heating.
9/10/2017 10:36:04 AM • Hoover Nextra... • Answered on Sep 10, 2017
Water comes out of bottom front panel onto floor
It's the drain pump ! $62.64 on line
3/30/2015 1:31:43 PM • Hoover Nextra... • Answered on Mar 30, 2015
0answers
I have rented a furnished flat and i dont know how
Methinks you could do with a manual- for now and later!
Now- unfortunately FixYa cannot provide manuals direct - members of the forum are just people from all over the world, probably working from home, and not representing any particular manufacturer ;-0)
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
10/14/2011 3:23:12 PM • Hoover Nextra... • Answered on Oct 14, 2011
I have a Hoover Top
Hi.
If it does make noise and does not spin it is usually the drain pump clogged. Disconnect power, reach the drain pump and check for blockage in there . If that is not the problem check in order drain hose at the back, lid switch, pressure switch, and finally pump and motor from underneath the washer. The switches and motors can be tested using a multimeter.
Here a page about drain/spin problem.
If you need parts see this tip explaining how to find parts and diagrams for most appliances: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
9/13/2011 12:11:32 PM • Hoover Nextra... • Answered on Sep 13, 2011
Where can i source a
Sorry, this FixYa Washer Forum does not supply service centre numbers, engineers, spares sources, software, installation instructions or prices; it is just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will either have to search in your local telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
John C
9/8/2011 2:28:36 PM • Hoover Nextra... • Answered on Sep 08, 2011
2answers
Wher can I get the
Manual
John C.
9/2/2011 10:05:58 AM • Hoover Nextra... • Answered on Sep 02, 2011
Looking for the manual but
You could try
http://www.mauritron2.com/service_manuals.html
or
http://www.mauritron2.com/operating_guides.html
We've used them in the past and found them very good.
Also if it is not listed then ask via the link
8/5/2011 7:48:58 AM • Hoover Nextra... • Answered on Aug 05, 2011
HI We have a Hoover
Thanks for choosing FixYa and welcome. You need to check your water inlet valve and make sure it is not defective. Check your water pump and make sure it is working right. The pump pumps the water into the washer.
5/19/2011 5:19:16 PM • Hoover Nextra... • Answered on May 19, 2011
0answers
My washing machine doesn't drain
Look under the machine to find the drain valve/pump. It might be clogged or faulty. When in the drain mode soon after the completion of the wash cycle , check for voltage to the drain valve/pump. If voltage is present and it does not work we are sure of the unit to be faulty but if there is no voltage then the program controller is faulty.
Check out the controller if faulty replace or clean the valve after removing for dirt, back flush test and refit. or if faulty coil replace.
8/30/2010 11:21:05 AM • Hoover Nextra... • Answered on Aug 30, 2010
Hello, my Hoover 700LB toploader won,t spin or
Hi just read your posting.Now the problem could be your motor or motor module.Have you got or can borrow an electrical test meter to test the motor and wiring? Please reply back and and I can guide you the finding of the fault and the repair.Also I will look at my manual to see if you can test for the fault without a test meter.Looking forward to your reply.
8/24/2010 2:43:02 PM • Hoover Nextra... • Answered on Aug 24, 2010
Spin Dryer doesn't work on Hoover 500M
Most probably the solonoid (also called brake motor). This is a 5 rpm motor that activates the drum to spin. I just replaced it two days back in my machine (Model 500M0AUS - you'll have to be specific when ordering or better take the old one to the spare part shop) which had a similar problem. The new soloniod I bought had a shorter cable length so I had to improvised when fitting. If soloniod is the problem then make wure the steel brake lever tooth fits perfectly in axle groove when you finish replaceing it. Do the replacement when the machine has fully stopped after completing its wash cycle.
Repair technician quoted 250 while the solonid costed me only 86. I did not charge labour to myself:)
Hope this is helpful.
5/29/2010 12:44:41 PM • Hoover Nextra... • Answered on May 29, 2010
MACHINE STOPS AT THE BEGINING OF CYCLE WITH LIGHTS
I am not a repair professional. I am a 78 year old man who has been making his own repairs for about 50 years. So the machine ID doesn't mean much to me. I came to fixya looking for a schematic for an really old AM/FM radio and just happened to see that more than 4,700 people were asking for help with a washer repair. I recently had a washer repair of my own and at that time I found an excellent video on youtube which showed me how to take my machine apart. This video (direct drive washer repair) made it possible for me to do my own repair. You probably don't have any idea of the wonderful help you can get from youtube videos. Your first stop should be at youtube. Just search for the help you need. You could search for "clothes dryer repair" or "clothes washer repair" or "dishwasher repair". If you are not able to view and/or download the videos, or after you've seen all you want to see, I suggest you go directly to www.applianceaid.com where they have very good step by step trouble shooting and repair information on washers, dryers. and dishwashers as well as other appliances. Another excellent site is www.acmehowto.com If you have a direct drive top load washer and need help taking it apart these youtube videos are wonderful help. I was so impressed with them that when I saw all these people needing help, I wanted to tell them about the videos. If you look at the back of your top load washer and the panel is solid (no small inspection plate to remove, which would indicate you have a v-belt drive) chances are you have a direct drive and this video (direct drive washer repair) is just what you need. After you've seen all the appropiate videos, or if you have a belt drive washer, you will probably still need help in determining what the trouble is and how to fix it. I suggest you go to www.applianceaid.com where they have very good trouble shooting and repair nformation on most washers and dryers, dishwashers and many other household appliances. I think you'll find what you need there. Another excellent site for DIY help is www.acmehowto.com Don't worry about the timer on a washer, they hardly ever go bad. I realize I haven't solved your problem for you, but I hope I have sent you where you can get help to solve the problem. Good luck with it.
12/18/2009 8:42:50 PM • Hoover Nextra... • Answered on Dec 18, 2009
Hoover Nextra HNT 2135 Top Load Washer Logo
57 questions posted
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Washing Machines
Most Popular Question
wher get
  • Washing Machines
