20 Most Recent Hoover HCA390K Bottom Freezer Refrigerator Questions & Answers
My fridge is a hoover a class frosgt free model
I had the same problem, the fridge insulation has gone and this means you need to replace it. There is no hope for it unfortunatly.
10/14/2013 1:39:38 PM • Hoover HCA390K... • Answered on Oct 14, 2013
2answers
Fridge freezer not getting cold and freezing
This issue is frequently seen when the valve that diverts refrigerant between the top compartment and lower compartment is stuck closed.
It is advisable to turn the whole unit off to prevent any further damage within and contacting a domestic appliances service engineer in your area as soon as you can to have the valve replaced and the unit regassed (If neccessary 50/50 if it does or not)
Please also be aware that this can be an expensive repair and in many cases it is more cost effective to replace the unit than get it repaired.
If you elect to replace be sure to buy one with a lengthy warranty as had this unit have been under warranty Hovver will have paid for the repair.
4/26/2011 11:24:08 PM • Hoover HCA390K... • Answered on Apr 26, 2011
Earth leakage trip
What about the light switch,lamp'S housing and in worst case a burn wire ? Good luck!
6/29/2006 4:14:57 PM • Hoover HCA390K... • Answered on Jun 29, 2006
I have a hoover fridge model HE505UF am chasing the freezer basket and the fridge lamp anyone knows where I can get one
Most spares are to be found here; https://www.espares.co.uk/browse/at1084ma107/fridges-and-freezers/hoover
8/17/2023 6:13:58 PM • Hoover... • Answered on Aug 17, 2023
Hoover HFLE54XK Fridge. Condensation in my Hoover under the counter fridge.
Goodness, that is tiny even for a UK fridge! https://www.rjelectrics.net/product/hoover-hfle54xk-freestanding-under-counter-larder-fridge-silver/ The problems are two-fold
  • Your fridge is basic and has no circulation fan.
  • The air in your home is too humid.
Try something like this from Screwfix UK to soak up and condense the moisture. Best advice though is get a new one and sell that one on Marketplace or Kijiji. https://www.screwfix.com/c/heating-plumbing/moisture-absorbers/cat14640001 ..
8/2/2023 9:28:19 PM • Hoover... • Answered on Aug 02, 2023
Hoover blade brush won't rotate. brush clean, belt good
If the brush on your Hoover Blade vacuum cleaner won't rotate, there are a few things you can check to try and fix the issue:
  1. Check for obstructions: Check the brush roll for any obstructions like hair, string, or debris that might be wrapped around it. Remove any obstructions you find.
  2. Check the belt: Even if the belt looks good, it might be stretched or damaged. Check that the belt is tight and not slipping. If the belt is stretched or damaged, replace it with a new one.
  3. Check the motor: The brush roll is powered by the motor, so if the motor is not working properly, the brush won't rotate. Check that the motor is working by turning on the vacuum and listening for a humming sound. If you hear a humming sound, the motor is working. If not, there may be an issue with the motor that requires professional repair.
  4. Check the brush roll bearings: If the bearings on the brush roll are worn or damaged, it may cause the brush to stop rotating. Try rotating the brush roll by hand. If it doesn't turn smoothly, the bearings may need to be replaced.
If none of these solutions work, it may be best to take your Hoover Blade vacuum cleaner to a professional for repair.
5/1/2023 6:46:37 PM • Hoover... • Answered on May 01, 2023
Hoover HV9 9H1075 Fridge. How to change the LED light please?
Question edited for clarity. You may be able to repair the board. If not, the whole module is replaced. https://www.google.com/search?q=Hoover+HV9+9H1075+Fridge.+replace+LED+light
2/7/2023 6:29:09 PM • Hoover... • Answered on Feb 07, 2023
Loud buzzing from Hoover Fridge.
You are not alone! https://www.google.com/search?q=hoover+hsc574s+buzzing+noise The condenser coils are underneath and it the perfect place to attract fluff, especially if you have animals. On mine, you open the bottom door and pull off the kick grill. There is also a panel on the back at the bottom that hides the compressor. That is an easier place to get the vacuum cleaner crevice tool in. You buzzing may be overheating, but it may also be a sign of impending failure.
Cleaning Your Fridge or Freezer - Advice Centre - Hoover ...
https://service.hoover.co.uk > advice-centre > cleaning-... Routine cleaning tips. Your fridge freezer should be regularly cleaned to ensure good hygiene practice. You should take care to remove obvious food debris, ...
1/22/2022 7:29:26 PM • Hoover... • Answered on Jan 22, 2022
How to change led light in hoover fridge
remove plastic cover then remove bulb
2/14/2021 4:28:23 AM • Hoover... • Answered on Feb 14, 2021
My 15 years old Hoover contour both freezer and fridge not cold enough even I switched on to the max
Refrigerator: Freezer not cold enough. Defrost system problems, dirty condenser coils, fan failures, leaky door gaskets or control problems can lead to your freezer not getting cold enough. ... The frost buildup blocks cooling air paths through the evaporator so the freezer doesn't cool well. https://www.searspartsdirect.com/diy/symptom/refrigerator-repair/1234589/freezer-not-cold-enough/ref0002
5/14/2020 10:16:10 AM • Hoover... • Answered on May 14, 2020
How old is my orchid Hoover 400litre fridge?
The Hoover Orchid is actually a rebadged Phillips Fridge. It would be over 20 years old now. I used to fix these in the mid to late 90,s
9/23/2019 2:14:36 AM • Hoover... • Answered on Sep 23, 2019
Hoover HCA390K Bottom Freezer Refrigerator Logo
11 questions posted
Top Hoover Refrigerators Experts
vince
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Hoover Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Hoover Refrigerators
Most Popular Question
fridge freezer not getting cold freezing
  • Refrigerators
