20 Most Recent
Karcher K DS 5500 Vacuum Questions & Answers
Hi, we have an
why dont you go too a hardware shop and ask if they have a water proof mastic filler may be able too repair it
No suction at all! help
check your vacuum at the pickup all the way thru the hose to the bag, you might be stopped up somewhere.
The on/off switch doesn't work,
It might be a simple switch issue. I would take it to a vacuum repair shop, one with free estimates. This way you will know for sure. and it should not cost you much?
5500 model
change the filters & ensure that the water container is properly seated in the machine.If the water tank is not sealing correctly the machine will not genrate any suction.
Karcher Press & Ex 800
The water pump is not working or the pump line is blocked. Check the pupm hose, if ok replace water pump
K5500 vs DS5500
The K5500 is an older model and doesn't come with the same amount of tools that the DS5500 comes with. You can usually tell the difference that the K5500 is an older model as its grey with yellow inserts. The latest DS5500 is all in yellow with black inserts and has some improvements made to the durability of its plastic body.
Karcher k5 full control- cannot remove hose from power washer
If twisting, pulling, and pushing are not working, then you may need to use some pliers to help loosen up the connection. You could also try wrapping the connection with a cloth or rag and applying pressure with a pair of pliers. If that still doesn't work, you may need to cut the connection and replace it with a new one.
