20 Most Recent Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System Questions & Answers
Have a 2000 Chevy s10 pick up (flex fuel)replaced
Well, First turn the ignition to ON and listen for a faint hum. If you don't hear anything. The pump is not running. (2) Have your mechanic check the wires to the fuel tank.(under the vehicle) and see that the pump is getting power. If no power, look around battery and wire connections. Hope that helps.
3/2/2018 2:22:10 AM • Minuteman... • Answered on Mar 02, 2018
2answers
99 chevy s10, fuel pump?
This happened on mine and at first i had 4v at the harness going into the tank then it eventually went to 0v im prettysure thats why the pump burnt up but anyway after much head scrtaching i tied into the ground wire coming out of the tank and grounded it to the frame and the truck is running fine there vehicles are known for bad wire looms
3/7/2011 5:25:48 PM • Minuteman... • Answered on Mar 07, 2011
What are the 2 plugs that plug into the s10 fuel
One is for the pump itself ,the other is for the sender that gives you fuel level.
12/31/2009 9:05:52 PM • Minuteman... • Answered on Dec 31, 2009
I'm working on a friends
The condition for setting a P1351 is the when the PCM (Powertrain control module) has ignition control (EST Enabled) and the RPM has dropped below 250. So I’m not sure if chasing this code is going to take us anywhere. Because the PCM is just reporting the obvious, as in the PCM is trying to keep the engine running but it still stalled. Thanks PCM but thanks for nothing we know the engine has stalled, what u have here is no injection of fuel into the engine by the Powertrain control module, if u put a test light on the injectors u should have one wire that is hot all the time with the ign key turned to on, if u don't check for a blown ECM 1 or ECM 2 fuse in the under hood fuse box, they are clearly marked, if the fuse is blown then you have a shorted engine harness, u will need to remove the harness and look for rubber through bare wires, this is common near the places the harness goes over or touches the engine parts.if you do have 12 volts to the injectors harness connector then you may have a PCM/Powertrain control module problem, the injectors are grounded by the PCM in sequence of firing order, u have one or the other of these conditions, this assumes that pressurized fuel (approx 55-60 PSI) is avil to the injector inlet.
10/10/2009 4:01:40 AM • Minuteman... • Answered on Oct 10, 2009
How to replace battery
Close the power Open UPS screw Then remove connection & batteries. set the batteries conect + RED - any colour close Charge one hr. start work.
from vinod
4/24/2008 2:33:25 AM • Minuteman... • Answered on Apr 24, 2008
Fuel pump relay switch
Look for the ECU fuse.
4/5/2008 12:15:32 AM • Minuteman... • Answered on Apr 05, 2008
Why does system parameter have all question marks on minuteman 320 se barfeeder
I would encourage you to contact Edge Technologies's technical support with your query. Below is the manual which includes troubleshooting but I understand you likely have that and need further assistance. https://edgetechnologies.com/ This is a professional group I am confident will respond to your queries. They also have an online forum. EDGE TECHNOLOGIES MINUTEMAN 320 SE OPERATION MANUAL Pdf Download ' ManualsLib Operation Manual: Edge Technologies - Minuteman 320 Bar Feeder
11/21/2023 3:16:40 AM • Minuteman... • Answered on Nov 21, 2023
Minuteman Endeavor series
Difficult to answer with so little information. But the batteries are first suspected ...
1/26/2015 8:20:26 AM • Minuteman... • Answered on Jan 26, 2015
Where can i get mastering machine learning Tips for Tackling Assignment
Mastering Machine Learning: Tips for Tackling Assignments Conquering machine learning assignments requires a blend of theoretical understanding, practical application, and strategic problem-solving. Here are some tips to help you excel:Foundational Knowledge: Solid Understanding of Concepts: Ensure you grasp the core concepts like supervised vs. unsupervised learning, different algorithms (regression, classification, clustering, etc.), and their applications. Mathematics and Statistics: Brush up on essential math and statistics, including linear algebra, calculus, probability, and statistical distributions. Programming Skills: Hone your programming skills in languages like Python or R, including libraries like NumPy, Pandas, Scikit-learn, and TensorFlow.Tackling Assignments: Thorough Understanding: Carefully read and understand the assignment instructions and objectives. Identify the specific problem you need to solve and the expected deliverables. Data Exploration and Preparation: Analyze the provided data: Understand the features, data types, missing values, and potential biases. Data Cleaning and Preprocessing: Address missing values, outliers, and inconsistencies. Feature Engineering: Create new features or transform existing ones to improve model performance. Model Selection and Training: Choose appropriate algorithms: Select algorithms based on the problem type (classification, regression, etc.) and data characteristics. Model Training: Train your model on the prepared data and tune hyperparameters to optimize performance. Evaluation: Evaluate your model's performance using metrics like accuracy, precision, recall, F1-score, or AUC-ROC curve. Experimentation and Iteration: Try different algorithms and hyperparameter settings: Compare the performance of various models to find the best fit. Cross-validation: Use techniques like k-fold cross-validation to assess modelgeneralizability and avoid overfitting. Regularization: Apply regularization techniques like L1/L2 to prevent overfitting and improve modelgeneralizability. Interpretation and Communication: Analyze results: Understand why your model performs well or poorly and identify areas for improvement. Visualize results: Use plots and graphs to illustrate your findings and insights. Clear Communication: Present your results and explain your approach in a clear and concise manner.Resources for Learning and Support: Online Courses: Platforms like Coursera, edX, Udemy, and Udacity offer comprehensive machine learning courses. Books and Tutorials: Numerous books and online tutorials cover machine learning concepts and techniques. Open-Source Libraries and Frameworks: Explore libraries like Scikit-learn, TensorFlow, PyTorch, and Keras for implementing machine learning models. Community Forums and Q&A Sites: Seek help and engage in discussions on platforms like Stack Overflow, Reddit's Machine Learning subreddit, and Kaggle forums. University Resources: If you're a student, leverage university resources like libraries, workshops, and professors' office hours. Remember: Practice is key: The more you practice, the better you'll understand the nuances of machine learning and improve your problem-solving skills. Start with simple projects and gradually increase complexity. Don't be afraid to experiment and try different approaches. Seek help when needed and learn from others' experiences.
4/24/2024 9:45:52 AM • Computers &... • Answered 2 hours ago
3answers
How do I find The best Roofing Service Contractor in Houston, Texas?
To find the best roofing service contractor in Houston, Texas, ask for recommendations from locals, check online reviews, verify licenses and insurance, and interview multiple contractors. Trust your instincts and choose wisely.
4/24/2024 4:31:29 AM • Computers &... • Answered 7 hours ago
Upgrades software
If you want to upgrade your software for example your operating system. Your systems unit support only for windows 7, windows 8 and windows 8.1. You may visit this website to download the latest driver for your operating system installed. http://support.lenovo.com/en_PH/downloads/detail.page?DocID=DS035527
4/22/2024 1:20:20 PM • Computers &... • Answered Yesterday
2answers
Como cancelar el winter driver
EnglishIt is a car, and cars are complexbut no car was told , maker, model , and year.we can not guess cars. post the VIN? and all that is knownname a problem what can't your car do right?name symptoms or evidence that is confusing to you.then answers can happen.onlygood luck , finding itand Mucho Gusto.my guess now is this is posted to computer forumand not to CARS !must be some odd traction controls thing'but 10,000 models of cars,
4/21/2024 5:41:42 AM • Computers &... • Answered 3 days ago
2answers
I need a product key
Have you actually purchased Visio, or are you just trying to get it for free?
As a software guy, I would have to advise against piracy. :)
There are several ways to get Visio for cheap. If you are a student, there are discounted versions available online and in stores. Also, you can check with your school for even cheaper options sometimes. Try the university bookstore if available. Or a Computer Science department maybe.
If you are working, and your company uses MS Office applications, find out if they have the "Microsoft at Home" program. You can get MS Office applications for really cheap that way. I can get Visio through my company's "Microsoft at Home" program for a few dollars.
4/21/2024 4:20:47 AM • Computers &... • Answered 3 days ago
Do you guys know some good custom web app development services?
DICEUS with 13 years experience. SIMFORM for modernizing legacy architecture. ColorWhistle for leads. PixelCrayons for tailoring to your specific needs.
4/18/2024 5:17:23 AM • Computers &... • Answered on Apr 18, 2024
My Employer Says They Are Going To Cut My Wages. Can They?
If you are in the middle of a contract, then cutting your wages is almost certainly a violation of your employment law rights. While I am by no means an expert on this matter, I did have a similar issue years ago - mid-contract wage cuts - and I hired anemployment attorney to fight the case on my behalf. It turned out that my employer was basically looking to scare people into taking the wage cut. They got into some pretty serious legal trouble for their transgression, and nothing happened to me in terms of wage cuts after that. If you are between contracts, your employer can re-negotiate your salary, but as far as I am aware, if you are in an agreed-upon contract, they cannot just decide to reduce your salary. If you want to settle matters, contest this action with support from a legal professional.
4/17/2024 5:31:31 PM • Computers &... • Answered on Apr 17, 2024
Implementing Reliable WordPress Website Backups: A Solution to Downtime and Errorsi wan
Keep a backup on your hard drive or a backup. The backup system is a free service supplied by your internet provider. If you use it daily or after every update, there will never be an issue.
4/16/2024 4:37:13 PM • Computers &... • Answered on Apr 16, 2024
Minuteman PRO1500E/1500VA/1050W/USB/RS232 /AVR 6 BATTERY BACK-UP OUTLETS (0784755151827) UPS System Logo
11 questions posted
Top Minuteman Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Minuteman Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Minuteman Computers & Internet
Most Popular Question
99 chevy s10 fuel pump
  • Computers & Internet
