20 Most Recent Digimate DGL32 32 in. LCD Television Questions & Answers
0answers
How do I reset my tv
To do a factory reset, you have to enter its service mode option. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter". http://electronicshelponline.blogspot.com/ Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
7/14/2014 4:21:56 AM • Digimate DGL32... • Answered on Jul 14, 2014
2answers
Where can I get a remote control for my Digimate tv 32
Contact the nearest authorized service center.
6/18/2013 3:31:55 PM • Digimate DGL32... • Answered on Jun 18, 2013
How do I adjust volume when tv is frozen?
Unplug the television. Check to see if the plugs are polarized (one bigger than the other). Sounds like if the plug was plugged in the wrong way could cause what we call a hot chassis. The tv is not properly grounded, it appears to be a grounding issue.
2/12/2012 11:24:07 PM • Digimate DGL32... • Answered on Feb 12, 2012
When i go to input devices no matter what i
First of all make sure you are also trying different input options on the INPUT MODE SELECTOR button on the remote control or on the TV itself. The TV may currently be stuck on an input mode which you do not have like HDMI.
Hook up a DVD player, power it up as well as the TV, and then press the INPUT button on the TV remote repeatedly to cycle through all the available input options to see if the display changes at all or gives you a signal.
If that does not work, try turning off and unplugging the power cord to your TV. Leave the cord unplugged overnight, then power the set back up the next day and test again.
If this fails to make any difference then you may have a faulty MAIN CIRCUIT BOARD in your TV.
These are fairly costly circuit boards to replace and do require some basic electronics skills to safely carry out the procedure. The DIGIMATE brand is not widely distributed so you may have some difficulty finding a replacement circuit board even online. If you have the skills to safely disassemble the TV enclosure, then open it up and get the exact part number for the main circuit board which should be printed right on it. Then go to EBAY.com and search for that part number to see if any replacements are currently available.
If you are unable to carry out the work yourself or the replacement parts are more than $150, then the repair may not be economically feasible. I would recommend using that money towards a new high quality, brand name TV like a SONY which would be much more reliable and would come with a solid warranty.
Please comment back here to this page if you have any details to add, have any questions, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck and take care.
Joe.
8/17/2011 3:05:13 AM • Digimate DGL32... • Answered on Aug 17, 2011
2answers
Hi I have a digimate
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
6/13/2011 11:05:40 PM • Digimate DGL32... • Answered on Jun 13, 2011
2answers
Wher can I buy replacement parts for DGL3201 in
Being an Elite Expert myself I was quick to see that you are a scam type outfit that keeps sending emails asking me to send money and then you might possibly find a solution. Well as it turns out if you would like to know how this was problem was solved - please send me $29.89 and I will provide you with the answer. Plus in addition if you act within the next three days I will do nothing else for you -- that's correct NOTHING!
Hurry don't delay - I'm sitting around waiting to answer your questions (for $29.89 of course)!
4/20/2011 8:16:25 PM • Digimate DGL32... • Answered on Apr 20, 2011
What is my screen resalutions
Your screen resolution is: 1366 x 768
I hope this helps you out and thanks for using FixYa.
3/22/2011 5:47:11 AM • Digimate DGL32... • Answered on Mar 22, 2011
Have picture and CC but
have you tried setting up a reciver with the audio out. Try this first then we can go from there
12/11/2010 11:52:22 PM • Digimate DGL32... • Answered on Dec 11, 2010
Tv will no longer turn on with or without remote
The problem can be cuased by main board, power supply module, etc.
Check the power supply module first, look for bad caps and check the DC otput voltages and ETC.
Please read my guide to get some basic understanding first.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on: Please see my basic troubleshooting guide here: http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Parts: www.shopjimmy.com Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps. Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series. Please post back what you find
12/11/2010 2:27:41 AM • Digimate DGL32... • Answered on Dec 11, 2010
0answers
Digimate model lt32c2p1 made in 7-7-05 turns on
Does "Screen is not lit up" mean that you still have sound? Please clarify this so that I can help you with your problem.
Sai.
11/28/2010 1:52:47 AM • Digimate DGL32... • Answered on Nov 28, 2010
Picture turns off but sound is ok.
Tv turn now,pictures only flashes a few sec. than died,than have sound left only?Yes than ur tv have those 1 or 2 long board call the LCD inverter boards are dead.These 1 or 2 long LCD inverter boards job are to help the LCD picture screen panel to have a backlight to produce a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those long refurbishes 1 or 2 LCD inverter boards for the replacement.
11/21/2010 5:05:27 AM • Digimate DGL32... • Answered on Nov 21, 2010
No sound ,but sound when the dvd is playing
replace the tuner of your lcd tv. or try to check the sound IF
10/11/2010 12:52:57 PM • Digimate DGL32... • Answered on Oct 11, 2010
Had a power surge through
make sure to plug in all major electronics and appliances to a very nice surge protector. If you have tried the TV in other outlets that you know work, and it doesnt display anything. It is probably power supply.
9/17/2010 7:19:32 AM • Digimate DGL32... • Answered on Sep 17, 2010
Not turning on
power supply is probably bad, not that expensive.
9/17/2010 7:12:58 AM • Digimate DGL32... • Answered on Sep 17, 2010
T.V won't turn on.....worked fine
A massive failure occurred when you tried to start it and the power source has been fried. time for a repairman, ASAP or the damage will go bigger and more expensive to fix.
8/21/2010 1:20:26 PM • Digimate DGL32... • Answered on Aug 21, 2010
Digimate DGL32 32 in. LCD Television Logo
60 questions posted
Top Digimate Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
Are you a Digimate Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Digimate Televison & Video
Most Popular Question
when go input devices no matter
  • Televison & Video
