20 Most Recent
Hisense TC24FS2H TV Questions & Answers
Can not get off channel 3 can not get other channels want change
Hi is the remote control faulty, ? Have you tried changing batteries? If this is not the issue have you the facility of changing channels manually? If you can and this has no effect try a hard reset to factory default through the remote control menus. If the fault is not hardware related this shuld rectify the tv.
Remote won't program tv.
Check the remote control for its infrared emission. If found OK, check and replace the infrared sensor in the TV. If you wish to get more details, check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
How to unlock Hisense Tv model TC20FS16
Hello
Press the LOCK button to lock or unlock the TV.
When the TV is locked, the screen will turn to blue background, and nothing can be viewed unless you press
LOCK again to unlock it.
OK
[Sometimes you may need to press the LOCK button more than 5 seconds contnously to unlock the TV]
OK.
Highsense tv universal remotes codes
These are the codes for Hisense. 0073 0182 0216 To know more about setup proceedings,
Visit the site named 'Electro-help' for
more details. Check this link and
select the site named above. View it
in 'Flip card' option, which can
be selected from the drop down box menu by the [Sidebar] tag, at the top left
corner of the display window. It will
make search easy. There
are more than 750 posts to different brand TVs now.
