20 Most Recent
Hisense TL2620 26 in. LCD Television Questions & Answers
Remove tv stand screws
To know more about this, you have to download the repair manual to this set by internet. Its disassembly section descriptions will have the details. If you're sound in electronics, and wish to get more details,
check this link.
http://electronicshelponline.blogspot.com/ Selecting the view option, either to
Mosaic
/ Time slide, can be selected by the
drop-down list, at the top left
of the display window, will make surf easy. You can also do a search, by type in the brand name/model
number/IC used, in the search box at the top right of the display window.
Sound goes to maximum by itself
Check your remote just to make sure you don't have a stuck button. Check the buttons on the TV as well. If they look ok, then you most likely have a bad Keyboard on the TV
The tw will not turn on
Good morning to youThe TV will not turn on. Have checked the power supply and the connections to the TV. It is better to check all cables and connections are in the right place.If this does not do any good it is the manual.Try ManualsOnline.com
My TV made a loud
Hello
The RF stage board in your TV is faulty. RF section includes Tuner, VideoIF and video detector. Open your TV and check whether there is any bulged or damged capcitor in that section. Anyway the power to RF section is not good. There is no service manual for your set published so far. Therefore, I cannot locate the exact fault point at your TV. Only can advice you the faulty section. If you have a trough knoledge in eletronics, you can follow the circuit. As far as video processing section is concerned, it is working well; that is why you can see the video clearly when you connect it with DVD.
Normally, RF section of any TV will be very complicated to fault locate. Special meters and instruments are needed to follow the circuit. Most of the components in that board will be [SMD]; Surface Mount Typs; and replacing them with normal soldering and desoldering techniques is impossible. So it will be best to get it serviced either by any experienced service technican or by the Authorised Service Center for Hisense at your town. Rough handling of these sections may cause permanent damage to the video amplifier section; which is now alright ofcourse. OK
What kind of cord do
You'll need a VGA cable ,the one you normaly use for a desktop computer from your tower to your monitor,surely your LCD supports that,Though you'll have to get your sound from your laptop still since this connection only transmit picture.Good luck...
I want to know hw
You should have an S video link, or use VGA (PC) input via appropriate cables.
I connect my laptop (Dell
Hello sir, hi, to send video to an external monitor TV or projector, you need to press Fn with a key corresponding to a square that looks like a monitor/projector or screen, (usually F5) check you function keys. Fn + function key with a screen icon.
I AM PLANNING TO BUY A 26 IN. HISENSE LCD HDTV
All LCD and Plama tvs brands are very simular,but the well known brands have more refurbishes electronic's boards out there to buy for the people who do it ur selfer repair for their tvs sets.The contrast and refresher rates is not standard.Must read the tv owner manual in each tv brand to find out.The most common in all LCD and Plama tvs problems are dead or dying capacitors in the power supply boards and it supporting boards.The CRT analog tvs it a Tube design in the past it hold heat better,that why doesn't kills capacitors as fast as today LCD or Pasma screen tvs.
TLM 2619 MODEL-DISPLAY PROBLEM
The most common cause for the loss of picture is a bad Horizontal Output Transistor
(HOT). but I would suggest you get a detailed
estimate. I think that this would cost you about $60.
The horizontal lines means the vertical amplifier or deflection system
has failed. There are over 100 components in this section and any one
of them, or most of them can be at fault. However, the most common
failure is the VOT or vertical output transistor (which is often buried
inside a chip).
The repair will cost around $250 plus or minus.
FEW TROUBLESHOOTING STEPS YOU CAN TRY:
ONE: Do a hard reset (just to make sure there is nothing in the coding
that is fowling things up). Unplug the power cord; leave it disconnected
for 4 hours. That will restore everything to factory defaults when you
power it back up.
TWO: Do the "whacking test" by banging your fist on a few strategic
places to see if there are any cold solder joints or loose wires acting
up inside the set.
If the above steps don't solve ur problem then I suggest you to go for a repair..
Goodluck..
