20 Most Recent
Olevia LT32HVE 32 in. LCD Television Questions & Answers
No channels
i had the same damn problem for 3 long hours but i found a solution
i have olevia 32 inch tv (720). all you gotta do is go to menu>setup>tv>auto channel search> cable> standrad search
Reset factory settings
To reset the TV to its factory settings, you have to enter its service mode option. Reset option can be selected in this mode. If you wish to get more details about how to enter, adjust and exit the service mode, check this site.
http://electronicshelponline.blogspot.com/ Pull
up previous posts or type in the
brand name and model number to of your set,
to its search box, and press '
Enter'.
No sound from dvi
tried to hooked up in other component input, just to ensure if compatible or supported in dvi.
Olevia 232-s13 32"
Just talked to Cust Supp, on the back you will see 6 round holes around the label. The screws needed will be 6mmx12mm. I have to do the same tonight. good luck
Cant get the hd to work
make sure connected via the correct input and if using a box signal is outputted correctly.
Cannot set color
HelloEnter into the Menu options, surf through, and come to picture adjustment window. Here you can set all adjustments to picture.
No picture
Hi logo and no signal can be a lot of things. You siganl board could be bad your backlight inverters caould be back. or your backlight itself can be bad. The first tihing I would check would be the backlight inverter.You can get parts for this TV at
www.interliquidparts.com
The color turns predominately green intermittently
Please try to play any DVD movies to determine if the problem is on the TV or on the cable/aerial connection and reception..If you play DVD and works fine?The TV is good but the problem is on the aerial antenna if you are using analog..and if you are using digital cable please double check the connection and cable box..or try to contact your cable provider..
