20 Most Recent Olevia LT26HVX 26 in. LCD Television Questions & Answers
I have a Olevia 26 tv that I have been using as a
http://content.etilize.com/User-Manual/10743166.pdf click on this link for PDF owner's manual
1/15/2018 9:51:51 PM • Olevia LT26HVX... • Answered on Jan 15, 2018
2answers
Can my Olivia LCD LT26 be hooked to an indoor had antennae? Once antennae hooked up what are next steps?
Yes. Depending on your location depends on how well it will work. If you are in the US you can go to antennaweb.org and get a fairly accurate idea if an indore antenna will work and what you can expect to receive. After you connect your antenna you need to do a channel search.
8/24/2016 11:59:27 PM • Olevia LT26HVX... • Answered on Aug 24, 2016
3answers
Olevia 26" flat screen
screen suddenly shut off. blue light in the right hand corner stays on but there is no picture
2/2/2016 1:31:20 PM • Olevia LT26HVX... • Answered on Feb 02, 2016
Lt26hvx olevia has vertical and horizontal lines will new main board p506201 fix
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/ Line faults to all LCD TVs; irrespective of its brand and size, will be similar.
9/13/2015 2:07:39 PM • Olevia LT26HVX... • Answered on Sep 13, 2015
CAN'T FIND OLEVIA 226T11 FIRMWARE UPDATE
Go to this website { http://www.scribd.com/doc/3303213/226-227-232-427-432-527-532-Firmware20Update20Instructions-EN } download the firmware update(right hand side of the web page), save it on USB stick(formatted FAT32 and empty) load it into your TV and follow the instructions carefully. The firmware is windows based, remember. Good luck.
8/11/2014 3:55:24 AM • Olevia LT26HVX... • Answered on Aug 11, 2014
I have no audio on my tv except for a humming sound. What can I do to fix the problem?
Could be an audio output transistor or a power supply problem
5/22/2014 8:28:15 PM • Olevia LT26HVX... • Answered on May 22, 2014
Multiple colored lines on my tv, then about 2
Unfortunately, lines in the screen is usually caused by a bad LCD panel. You eliminated the T-Con as the problem after replacing it. A replacement LCD panel is very expensive. Buying a new TV is cheaper. Sorry.
11/4/2013 6:10:32 PM • Olevia LT26HVX... • Answered on Nov 04, 2013
Set up instructions
See owners Manual.All instruction are there.
11/3/2012 8:31:44 PM • Olevia LT26HVX... • Answered on Nov 03, 2012
How can i put my OLEVIA, model-- LT32HVE tv, into user mode?
Please follow guidelines in operation manual.
8/1/2012 4:43:23 PM • Olevia LT26HVX... • Answered on Aug 01, 2012
The volume is not working when I have it on tv but it will work when I put a movie in my DVD player
Try disconnecting DVD from TV, had same problem
6/29/2012 11:14:44 AM • Olevia LT26HVX... • Answered on Jun 29, 2012
Lost channels how do i restor
Try to program with the remote first=in menu selected auto program-also if a box for cable/sat is in line consider it may be damaged.A simple test is to see if a DVD etc works at all on set---try to see what is and what is not working one at a time.
4/28/2012 1:35:16 PM • Olevia LT26HVX... • Answered on Apr 28, 2012
I want to plug in outside speakers which plugins do I use?.
There are 2 Red and White plugs on the back generally called Audio Out that you can use to plug speakers into. Or if they are computer speakers you can just plug them into the headphones port
4/25/2012 12:08:48 AM • Olevia LT26HVX... • Answered on Apr 25, 2012
3answers
Lcd tv picture problem
My 3 yr-old 30" Olevia LCD HDTV lost picture after being on for about 1-2 min. Does any one encounters a similar problem or has any suggestion as to how or wherther it can be fixed. Thanks.
2/25/2012 10:40:26 PM • Olevia LT26HVX... • Answered on Feb 25, 2012
Olevia LT26HVX 26 in. LCD Television Logo
85 questions posted
Top Olevia Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Olevia Televison & Video
Most Popular Question
olivia lcd lt26 hooked indoor antennae
  • Televison & Video
