20 Most Recent
Vizio P4221 Television Questions & Answers
Blank Screen With Sound!
in 1965 a color tv was a years wage for an electrician.
they are cheap today.
yours has an 80 volt power supply problem.
Vizio Sound Problem
I've seen the same problem, went thought a couple of cable boxes. Turned out to be an AC line problem. Try plugging the TV into a different out, maybe in another part of the house.
Plasm tv
It takes a fair amount of power to make an audible noise like
this. Only the power supplies are suspect. Either the low
voltage supply that runs the TV's "smarts" or the high-voltage
supply that powers the screen. Either way, it is bad news - You
do have this under warranty don't you?
I don't care which of the new TV technologies you buy, they are all
doomed to expensive repairs. Always keep them under warranty.
Norcent model 2723 lcd tv
if u can resolder urself with a pencil solder and there are products to remove that resin u said u could get all that at a radio shack beats the hell out of paying 350 u could do it urself like around for 20 bucks just make sure ur power is out of the wall before anything
Plasma dead
Unfortunately its a trip to the repair shop. This model is no longer available so it might make that much harder to get parts. Most reputable shops will look at it for a low labor charge and tell you your options. If they fix it they will subtract the labor for looking at it. Consider if it costs less than 50% of the cost to buy a new one it's worth it. Over that buy a new one. Also consider how old your TV is and much longer will it last. Best advice I can give you.
Vizio V705-H1 started having display issues. The background seems okay but words have tracers.
Check Connections:
Ensure that all cables connecting your TV to external devices (such as your cable box or gaming console) are securely plugged in. Loose connections can cause display anomalies.
Test Different Devices or Apps:
Try using other devices or apps with your TV to see if the issue persists. If the TV's menu looks fine but a specific device is causing trouble, that device might be the culprit.
Adjust Picture Settings:
Navigate to the picture settings by pressing the 'Menu' button on your remote.
Experiment with different picture modes. Sometimes a minor adjustment can resolve display problems.
Soft Power Cycle:
Unplug your TV from the power source.
Press and hold the power button on the TV for about 3-5 seconds (this helps drain any residual power).
Plug the TV back in and turn it on. Some TVs also have a 'Soft Power Cycle' option in their settings menu, so check there too.
As you have tried a reset, that takes us to the options of contacting Vizio support and/or your warranty.
Vizio all in one computer VIZIO CA-27 voltage and part number for subwoofer/power supply replacement
The power supply/subwoofer for the VIZIO CA-27 series all-in-one PCs is identified by the part number 715G6960-P02-001-002S or ADTVE1825AC71. The power supply connects to the motherboard via a proprietary dual jack Audio/Power cable. I couldn't find specific voltage details for the subwoofer/power supply in the available resources. For precise information, I recommend checking the user manual or contacting VIZIO customer support directly.
Why is my Vizio TV stuck on mute.
The one logo is coming from the set top box that is supplying the signal, cable box, satellite box, Android box etc. Look for Mute on that remote, or cut the power to all your devices by removing the wall plugs. Wait 15 minutes and plug back in.
