20 Most Recent Nostalgia Electrics Nostalgic 841.062 Shelf System Questions & Answers
You put sugar or "floss" in the center of the spinner. When it heats up (takes a while) a spider web like material forms in the bowl. You take a "paper cone" and twirl it around to collect this which is the cotton candy! Find a party store to get the cones and you can also get the "floss" which is sugar with a bit of coloring and sometimes glycerin.
Clean the spinner after use.
Nostalgia... | Answered on Aug 23, 2009
release the orange case from the back and slide forewards.Note,use athin knife blade to ease the case sides 2no. from holding points on head.BUT THERE MUST BE A BETTER WAY???.
Nostalgia... | Answered on Nov 26, 2009
Check the belt- if it is a belt drive turntable.
Audio Players &... | Answered 14 hours ago
Check your Ariel connections for corrosion (clean them all up)
Have you relocated the unit?
Have you placed/relocated any other electrical devises near it recently??
Audio Players &... | Answered 18 hours ago
Hello Dilum, make a test to control the sound level of the speakers connected to your harman kardon, you must press for more than two seconds the test key that is on the front panel, in the set of keys at the bottom
With the Test, you will be able to check the volume of each speaker individually, this is explained in the user manual on page 4 Item 9
If with the test, the level is fine, then you would have some problem in the recording or the program you are listening to
I hope I can solve the problem
Greetings Franco Dosil
Hola Dilum, haga una prueba para controlar el nivel se sonido de los parlantes conectados a su Harman Kardon, debe presionar por mas de dos segundos la tecla test que se encuentra en el panel frontal, en el conjunto de llaves en la parte inferior
Con el Test, va a poder chequear el volumen de cada parlante en forma individual, esto esta explicado en el manual de usuario en la pagina 4 Item 9
Si con el test, el nivel esta bien, entonces tendria algun problema en la grabacion o el programa que este escuchando
Espero pueda resolver el problema
Saludos Franco Dosil
https://data2.manualslib.com/pdf/7/658/65714-harmankardon/avr20ii.pdf?3e1777e124b0c9a1878f4d39601e577d&take=binary
Audio Players &... | Answered 22 hours ago
please give more info of your problem. on what source are you not having sound? in all sources like your tuner, auxilary, tape CD etc...?
Audio Players &... | Answered Yesterday
Looks like it's very secret
4 Answers What is the secret code for literacy planet turtle knock ...
www.fixya.com/support/t24424275-secret_code_literacy_planet_turtle
  1. Cached
  2. Similar
May 15, 2014 - Ammoforall. SOLVED: What are cheat codes for turtle knock on ... 10 answers Jul. 20, 2017 1 Answer What is the secret code for literacy planet ... 10 answers Mar. 1, 2017 What is the secret code of turtle knock? 11 answers Nov. 24, 2016 Literacy planet cheat codes turtle knock 9 answers Sep. 28, 2015 More results from www.fixya.com
What are some cheat codes for Turtle Knock on Literacy Planet ...
answers.wikia.com/.../What_are_some_cheat_codes_for_Turtle_Knock_on_Literacy_...
  1. Cached
  2. Similar
... When, Why, How, etc..." in your question. Nothing to ask? Click here for a random, un-answered question. in: Literacy Planet, Cheat codes, Secret codes ...
What is a secret code in literacy planet on turtle knock? ' Wikianswers ...
answers.wikia.com/wiki/What_is_a_secret_code_in_literacy_planet_on_turtle_knock
  1. Cached
neverrunoutofshots: unlimited shots (MAY NOT WORK)
1 questions posted
Top Nostalgia Electrics Audio Players & Recorders Experts
 Grubhead
Grubhead
Marvin
Marvin
Are you a Nostalgia Electrics Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Nostalgia Electrics Audio Players & Recorders
Most Popular Question
need instrution
  • Audio Players & Recorders
