20 Most Recent Tasco 750 Monocular Microscope Questions & Answers
2answers
How much is this model
Amazon has used ones for about $25. New they are not worth that much more. They are designed more as a toy, then a real microscope.
3/12/2019 11:42:23 AM • Tasco 750... • Answered on Mar 12, 2019
How do find a replacemnt bulb for this tasco 750 x zoom microscope?
contact tasco. try ebay for a month (search various combinations of keywords). notify by email. 21.january.2015
8/23/2015 10:21:42 PM • Tasco 750... • Answered on Aug 23, 2015
2answers
Microscopy; Relatively large spots on unknown surface obstructing view
HELLO..
There is five part in microscope
1. Eye piece
2. Binocular tube
3.Objective
4. magnification changer or joom accembaley
5. illumination segment
Try to make it out which part is gives a effect to your vision.
as per my suggesition illumination asembely you just clean it first.
keep in touch
regards
INDRAVIJAY
5/19/2013 9:28:54 PM • Tasco 750... • Answered on May 19, 2013
0answers
Need bulb
Be the first to answer 1/21/2013 3:48:30 AM • Tasco 750... • Posted on Jan 21, 2013Be the first to answer
3answers
I picked up a Bushnell 1200 power microscope at a
You will need to focus in on the slide. There should be 2 1" diameter knobs on either side of the stand, and just to the rear. Those knobs control the height of the stage (where you slide sits). Slowly raise or lower while looking into the eyepiece. At some point something should be see, if the microscope is working properly.
Sometimes it is easiest to start with the lowest magnification. On the outside of the objective (little lenses hanging down that can be rotated) there should be some numbers written on them (usually 4, 10, 40). Those numbers reference your magnification. If you multiply that number by the eyepiece (10) magnification, you will get your total magnification, so start out with your 4x. It will give you the largest field of view, so it is great for finding whatever it is that you are looking for on your slide. It is also the easiest one to get focused. The higher you go in magnification, the smaller the field of view, thereby the more difficult it is focus in on your sample.
9/5/2011 8:05:52 PM • Tasco 750... • Answered on Sep 05, 2011
0answers
How much its cost in rs
3/6/2011 8:43:30 AM • Tasco 750... • Answered on Mar 06, 2011
0answers
My tasco microscope light will not turn on and the battery pack
sometimes when a battery causes corrosion inside something, you can clean off the springs or contacts where the battery goes. if i can, when that stuff happens i use sandpaper or something like that to clean the contacts. you cant always get sandpaper where you need it though. just try to find something to like scrape stuff off if its on there
5/1/2010 5:01:41 AM • Tasco 750... • Answered on May 01, 2010
0answers
Manual for a microscope
Try Ebay--may have to buy the micro aswell but it won't cost much,have you tried the Tasco website in case a free d'load is avail?-kind regards martin r
3/27/2009 11:50:31 AM • Tasco 750... • Answered on Mar 27, 2009
Fixing one
You must detach the bottom cover of the base of the microscope by taking off the 4 or 5 screws that keep it attached. That should reveal the wiring to the socket and bulb base.
12/22/2008 10:15:21 PM • Tasco 750... • Answered on Dec 22, 2008
Manual
I found out that Tasco microscopes have been discontinued quite some time ago. A Company called Bushnell 1-800 423-3537 who gave me the number of ABO 305-859-2010 Tasco microscope 750X # 60750-0 call after 3pm. They do not have my manual but can answer questions or send a similar manual. I have to call back stiil hope this helps. Zoom
3/19/2008 4:53:08 PM • Tasco 750... • Answered on Mar 19, 2008
2answers
Problems with viewing under low magnification (20x) only red stain
hello..
For the red colour partical your illumination angle should be 0 degree.
As per you exepirience you are getting red at low magnification and not getting at high magnification. at the higer magnification the light deviation you can apriciate more then lower.
try to adjust your light source focusing lenc at higher magnification so at the lower it will be more better,
for the further problem you can contect me any time,
regards.
INDRAVIJAY
3/10/2008 4:26:13 PM • Tasco 750... • Answered on Mar 10, 2008
2answers
Microscopes
sir,
Diffrent company having their own system for microscope arm balacing.
Tell me which one microscope you have.
Auxillary arm or microscpe body sloly come down ward.
tell me problem is consult with which part..
INDRAVIJAY
3/10/2008 4:02:28 PM • Tasco 750... • Answered on Mar 10, 2008
3answers
Optic lens tube separation
image.php?productid=16148sir,your microscope tube with the eye piece is screw joint with microscope body. Rather part is friction fitted as well as there is a proper place to mount it.you can do the gluing but first of all be clear that part should be not a movebale part other wise you will have dificulty for fine focusing.
for the further quotation dont be hazitate,
INDRAVIJAY
3/10/2008 3:49:47 PM • Tasco 750... • Answered on Mar 10, 2008
Tasco 750 Monocular Microscope Logo
Popular Tags
32 questions posted
Top Tasco Science & Laboratory Experts
ADMIN Andrew
ADMIN Andrew
Don A
Don A
Collins Mccoy
Collins Mccoy
Are you a Tasco Science and Laboratory Expert? Answer questions, earn points and help others
View Most Popular
  • Tasco Science & Laboratory
Most Popular Question
picked up bushnell 1200 power microscope
  • Science & Laboratory
