20 Most Recent
Bunn Coffee Grinder Questions & Answers
My grinder is jammed How
what kind of grinder so you have.
if its jammed then you need to check the motor that there is no obstacle comming to the motor.
basically you have to open the grinding chamber.
BUT THEN YOU NEED TO ADJUST THE GRINDING QUALITY.IF YOU DON'T KNOW THEN DON'T DO IT
if you need help then reply me back
thanks
rate me for this
I have a bunn coffee
It sounds as though your grind is out of adjustment. The grinder is probably set too fine. I have not worked on a G3 grinder but I would think it is like the Bunn G2. On the front knob you will find 2 small set screws and one larger adjustment screw (in the middle of the knob)
1. Set the selector knob to finest setting (Espresso or Turkish)
2. Loosen the 2 set screws about 2 turns.
3. Activate the start switch (you must activate the "bag switch" behind the chute)
4. With the grinder running, SLOWLY turn the center screw clockwise only until you hear a very slight whirring sound (this is the burrs touching).
5. Then, back off the center screw counter-clockwise about 1/8 of a turn, shut off grinder and re-tighten the set screws.
Check the grind in the "drip" setting by running a few beans through... the grounds should be about the consistency of sand. You should get a better flow through the machine with the grind adjusted properly. You may want to check the cleanliness of the hopper in the top... I have seen these dirty enough to impede the falling of the beans to the grinder.
Also, whenever you remove (for cleaning) the 2 larger screws that hold on the front "plate", be sure to put them back in evenly... kind of like one would with a wheel on a car- Finger-tight then slightly tighten each on a little at a time (back and forth) until tight.
Hope this helps.
Coffee beans are not fine
Have you replaced your blades recently? If you will call contact customer service, we can send these out to you free of charge.
I cant see my BUNN BT Velocity date code on my brewer I was told it is 6 digits... it starts with what number??
To locate the date code on your BUNN BT Velocity brewer, you can try the following:
- Check the bottom or back of the brewer: Look for a label or sticker on the bottom or back of the machine. The date code is typically printed on this label.
- Inspect the sides or inside the brewer: In some cases, the date code may be located on the sides or inside the brewer. You may need to remove any panels or covers to access the label or sticker.
- Consult the user manual: If you have the user manual for your BUNN BT Velocity brewer, it may provide information on where to find the date code. Refer to the manual for specific instructions or contact BUNN customer support for assistance.
If you are still unable to locate the date code on your brewer, I recommend reaching out to BUNN customer support directly. They will be able to provide you with accurate information and guide you in finding the date code on your specific model of the BT Velocity brewer.
Bunn my cafe mcu red light flashing. Water does not heat. Water will run out if brew button pushed, but of course it is cold
I have the identical problem, and I noticed it this morning after there were 2 very brief (seconds) power outages the previous night. Reading around the internet I read that the fuses inside the unit are the likely culprit, and need to be replaced. You can buy fuses made by others, for this unit. But not from Bunn. And there are video instructions around that show how to do it. The fuses are crimped on, not soldered. Mind you, I haven't tried to do this, yet, but that's what I read. Good luck!
