20 Most Recent
Acer Aspire One D257-1497 Intel Atom N570 1.66GHz 1GB 320GB 10.1 Win7 Burgund Questions & Answers
Wil not connect wireless works fine wired
Hi, The problem is, in this case, the netscape program installed on your computer. Try uninstalling the program and use internet explore to connect to the internet. Incorrect file associations could be the result of your underlying issues connecting to the net. To remove netscape from your computer click the start button then open control panel. Find and open Programs and Features. Find netscape and remove it. Good Day
Acer aspire one d257-1497
OK, some possible reasons why this is happening. My first thought is your wifi drivers may be corrupted which are different then your Ethernet one's. Also, a setting was changed by you the user, or the internet itself. An example of this is when we install updates or programs, they often have additional software packaged along with them like toolbars, ect. You can try navigating through your wifi settings by starting with your connection icon by your clock. From there you can select different places associated with your wireless settings. I also recommend going to the control panel, programs and features, and carefully removing installed programs that you may recognized as unnecessary and not needed. When doing this pay close attention to the dates they were installed as this can tell you a lot. Most likely programs with older installation dates are ok and or necessary. You will see what I mean when you get there. Good Day
Mpowering technology pop up
Couldn't get rid of mpowereing technology pop up. Tried every solution offered by the internet. Finally I noticed when I powered up my computer the pop up showed up even before the computer loaded anything. I turned off the power to the monitor and powered it back up an viola, pop up gone. The Acer monitor had generated the pop up.
My Acer X1110 switches off as soon as blue light comes on?
it needs service, and service manuals are hard to find on anything by the likes of ACER.
this projector worked for 12 long years, did you own it 12 or bought a bad projector, no history told as I can buy dead projectors all day long. and hard nut problems even hacking done.
Acer X1110 data projector Standard throw projector..
did you know most projectors have serious grade protective devices inside??? (tamper and overheating are 2)
did you read owners manual page 32 yet, errors.
LED codes.?
there are 4 LED, and all 4 matter, projector turned (ON) (not one =1)
also in pairs glowing and also if blinking or not, so read page 32
it tells all that.
my guess is overheat failures, even cold, due fan slow or packed in lint after 12 years of use and no service done,.
https://manualzz.com/doc/49497108/acer-x1110-user-manual
some have dust filtler
a shop first cleans is out first, and check fan RPM with and LED tachometer.
this is all SOP.
''e'' button :acer empowering technology
That button can be set using the utility on your programs list
It maybe that you accidentally turned it off or set it to do some other task.
Start there first before re-installing the program that sets it.
That is on one of the cds that should have come with it and can be installed by itself.
