20 Most Recent
Hoover F6055-900 SteamVac Maxextract LS Wet/Dry Vacuum Questions & Answers
Www.hoover.com
Having never used a steamvac I can only only offer this....pump
and nozzles dispense solution....Is the pump on and working?
Are the nozzles clear? This is all I have...hope it helps.
Regards,
Dennis
My Hoover SteamVac Max Extract 77's dirty water
There are several possibilities for low pick up. The most common problem is that the lid is not correctly seated on the recovery (lower) tank. It is also possible that the rubber seal on the motor standpipe is out of place. The round tube on the bottom of the tank sits against the seal. Remove the tank and look for a large rubber ring on top of a plastic pipe. A less common issue is damage to the rug nozzle because the screws holding it against the carpet have been broken loose by dropping the shampooer on it's nose.
My max exract 77 causes circuits to break
you need to plug your cleaner into a outlet that does not have other devices in use ,such as a lamp, tv , stereo/radio. If you use a receptacle In the kitchen you will probably not blow the breaker. make sure other kitchen appliances are not in use. - toaster , mixer, coffee maker etc.
My max extract 77 hoover wont spray
Make sure all water lines are not clogged with anything 1st. Then check to see if the switch/lever or button that actuates the spray is functioning/working. If it's a mechanical switch/lever etc, see if you can take it off and clean it thoroughly and check to make sure there are no broken parts. If it's an electrical switch/button or lever, you need to check and make sure it's clean, and all the contacts to wires are NOT broken or damaged. You may have to replace parts if they don't function.
