20 Most Recent Champion G5-PG-710 650 Watts Juicer Questions & Answers
0answers
10answers
Champion Juicer stopped working
Hi I had the same problem yesterday and emailed Champion Juicer about the problem here's their reply below, his suggestion worked. Hello Duane, Your machine is equipped with a magnetic start system which will only allow the machine to start when you have the screenholder all the way in place just as you would have it to start juicing. If you do not have any parts on the machine it will not start. Please assemble it again and give it a try. If it still wont start call me at 209-369-2154 for further assistance. Thank you Carl
4/30/2012 9:05:22 PM • Champion... • Answered on Apr 30, 2012
The unit will not turn on. The wall plug was
It could be one of many things. Have you tried cleaning the juicer? Maybe take to a small appliance repairer or call the manufacturer.. I will be glad to continue to assist you.
FixYa Support
8/23/2011 1:22:07 AM • Champion... • Answered on Aug 23, 2011
0answers
Juicer stopped working suddenly. Nothing happens
The pulp container was a problem. When you take out thecontainer, you will see a little (very very small) hole that if you push withsomething like toothpick it makes sound like "click" I guess when weput the pulp container back, the container is supposed to push the safetybutton ( bottom area), but I think the part of the container that push thebutton was broken, and it didn't start, so you can just put something smallinside the hole before you put the container back to the juicer, so it coversthe missing part. The motor could be bad also. Try this solution, if theproblem still exists then you probably need to call manufacturer. Good Luck.
7/16/2011 5:55:26 AM • Champion... • Answered on Jul 16, 2011
Motor won't work on Champion unless I press on part
it probably has developed a loos connection inside. Pressing on that part reconnects the loose connecion inside the machine. If you are someone with a good mechanical aptittude, you may open it and somehow make a hood connection again. The problem should be obvious, and straight forward to fix.
6/28/2009 12:40:51 PM • Champion... • Answered on Jun 28, 2009
Safety cut off switch does not work so switches on
micro switch ?
5/12/2021 1:32:55 AM • Champion Juicers • Answered on May 12, 2021
2answers
Cleaning inside shaft of champion juicer cutter
Soak it in Hydrogen Peroxide or vinegar.
9/20/2019 1:34:22 PM • Champion Juicers • Answered on Sep 20, 2019
Champion juicer model G5-NG-853S stopped working. Do you have a repair facility somewhere in central Florida? Are there any warranties for this juicer?
FIXYA is not a manufacturer or seller of juicers. You need to search elsewhere for assistance with repair or warranty replacement.
3/28/2018 4:10:19 PM • Champion Juicers • Answered on Mar 28, 2018
2answers
Cleaning inside the cutter
I've been using my Champion for about 20 years, and have always used a very thin coat of olive oil on the turn shaft before sliding the cutter on. I've also used it before I've used the grain mill, and it has been fine.
If I were you, I think I would get out as much Crisco as I could with a chopstick (or something similar), put in some liquid soap, and some hot water. I would think that would loosen anything that was compressed or stuck. It might take a few times, but that's what I would try....or you could order a new cutter from Champion. I've had to order parts from them in the past, and they have been great.
Hope this helps.....
1/28/2016 6:28:45 PM • Champion Juicers • Answered on Jan 28, 2016
2answers
Problems dismantling champion juicer
It's like a suction is created. I have had this happen. I managed to get mine off with a blunt knife to give a bit of leverage (not ideal I know to put a knife near an expensive piece of equipment but it worked for me) Once you have the blade cutter off I suggest oiling the metal prong that it sits on with something like vegetable oil or olive fairly regularly to avoid this happening again.
1/28/2016 6:05:52 PM • Champion Juicers • Answered on Jan 28, 2016
What the oil type for champion 4500 habart
1/10/2016 8:37:10 PM • Champion Juicers • Answered on Jan 10, 2016
Where can I get my juicer repaired I live in NJ 07003
Look in Yellow Pages , BEWARE Might br cheaper to BUY a new Juicer, as Repairs expensive.
3/11/2015 2:17:30 PM • Champion Juicers • Answered on Mar 11, 2015
How to stop gass from going into mufler on a 6500 champion generaitor when it is not running
there should be a fuel tap directly under the fuel tank. It should not be leaking fuel through unless there is a problem in the needle and seat ( staying open and not sealing off)
2/12/2015 1:33:35 AM • Champion Juicers • Answered on Feb 12, 2015
Champion juicer can't get metal plate off bottom, screws tight
Ants OMG! what a nuisance. I suggest calling The Wholistic Research company who sell champions as they may be able to help
5/23/2014 10:34:27 PM • Champion Juicers • Answered on May 23, 2014
Replace carbon brushes
What model?
8/25/2013 3:23:11 PM • Champion Juicers • Answered on Aug 25, 2013
Champion G5-PG-710 650 Watts Juicer Logo
Popular Tags
10 questions posted
Top Champion Juicers Experts
ADMIN Andrew
ADMIN Andrew
Aron
Are you a Champion Juicer Expert? Answer questions, earn points and help others
View Most Popular
Champion Juicers
  • Champion Juicers
Most Popular Question
juicer stopped working suddenly nothing
  • Juicers
