20 Most Recent
Wolf Range fs-0-27-ft36 Gas Kitchen Range Questions & Answers
Whenever i light the gas
The electrode (spark plug) for that burner is not telling the spark module the burner is lit and go ahead and turn off the spark. That electrode and the wiring on it need to be replaced,from that burner back to the spark module.
I hope this helps you to repair the problem with you stove,
Gene
My gas stove keeps on clicking after the burner is
your range has a Electronic spark modual with reignition. First look at the electrods on each burner and make sure they are clean all the way around them. (( dirt can cause them not to send the votage back created by the heat. )) If this does not solve the problem then you will need a new spark modual system.
Wolf range 36'' gas range
this sounds as if your gas suooly pressure has dropped and the ignitor
does not light until a significant amount of gas is in the oven. check
your gas supply line for a bend or kink, also chec if the shutoff valve is
partially closed.
Oven door blew open, late ignition and broke the door
Call the gas company have them come and look at the system since it built up presssure and blew the door pen is not something you want anyone online talking to you about. Or get a tech this is a very serious problem and thankfully no one was injured in this situation
My wolf rage doesn't light anymore by turning a nob
some models have one gas pilot for 2 burner front and rear and there is a small pipe that goes front the burner to to the pilot, the burner has small holes facing the pipe the goes to the pilot that's where you take a paper clip or a safety pin and clear or clean the holes, the same thing on the electronic ignition, but some electronic ignition they have a spark right nest to the burner and by looking at the other burner that are working you can see where it's sparking, and clean in between the burner and the spark.
Wolf broiler will not light
defective ignitor. Oven ignitors can glow and allow enough current through to open the oven gas valve but just not produce enough heat to ignite the gas immediately
How to reset error codes
www.subzero-
wolf.com/.../dual-fuel-
range-
error-
code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
www.subzero-
wolf.com/.../l-series-built-in-
oven-
error-
code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
www.subzero-
wolf.com/.../wwd30-warming-drawer-
error-
cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
appliantology.org > ... > The Kitchen Appliance Repair Forum
12/25/2015 11:56:52 PM •
Wolf Range...
Answered
on Dec 25, 2015
