20 Most Recent Panasonic TC-P50S30 VIERA 50 Class 49.9 Diagonal S30 Series Plasma, Aspect Ratio 16:9, Native Resolution Number of Pixels 2073600 1920 x 1080, Moving Picture Resolution 900 lines, Shades of Gradation 6144 equivalent, 600Hz Sub-field Drive, 24p Playback 2:3, De Questions & Answers
I am getting a 14 blink code on my Panasonic TC-P50s30. Do you know what is causing this
Sounds like main digital board fault. 14 blinks denotes that. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/ http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
7/14/2016 4:21:37 AM • Panasonic... • Answered on Jul 14, 2016
14 blinks on my Panasonic TC-P50S30. Any Ideas?
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
11/20/2014 6:07:01 PM • Panasonic... • Answered on Nov 20, 2014
Will not turn on
We recommend you remove all HDMI cables from the TV and unplug the unit's power cord. Then wait 30 seconds and test a different electrical outlet. If the problem persists, we recommend you contact a local authorized servicer.
3/21/2014 4:54:22 PM • Panasonic... • Answered on Mar 21, 2014
No picture on my Panasonic TV
Please unplug all HDMI cables from the TV and test a different electrical outlet. If the problem persists, please use the below link to locate an authorized service center in your area. Where to Service Panasonic Products
3/14/2014 3:08:10 PM • Panasonic... • Answered on Mar 14, 2014
Word Debug showing on Screen
We regret to inform you Panasonic TV's do not use any errors similar to Debug. We recommend you contact the source provider that the TV is connected to.
3/6/2014 5:51:39 PM • Panasonic... • Answered on Mar 06, 2014
Will not power up
If you have a direct power cord attached to the TV, try another cord like it and turn it on. That rules out the power cord, unless the power fuse at your home fuse box was flipped, or the power fuse to the TV was blown. Sometimes a Power surge or failure trips fuses or blows a fuse; so check them first. If all the Fuses or Circuit Breakers are working just fine, then the problem is more serious. The condition may now relative to either the Picture Tube and/or Projector Tubes, the power transformer, or damaged mainboard of the appliance. Any of these mentioned herein need a professional technician to check the circuitry for faults.
12/24/2013 11:45:23 PM • Panasonic... • Answered on Dec 24, 2013
My Phone is Panasonic KX-T7730 unable to call another extension
Unplug all the extensions and then plug them back in one at a time. https://www.google.com/search?q=Panasonic+KX-T7730+unable+to+call+another+extension ..
3/17/2024 4:53:10 PM • Panasonic... • Answered on Mar 17, 2024
I have Panasonic workio DP 3030 i need driver for windows 8.1 or 10 from panasonic
There is no driver for 8.1 or 10. The support stopped in 2007.
11/23/2023 8:56:31 PM • Panasonic... • Answered on Nov 23, 2023
Panasonic DP-C265 showing E05-01 error as soon as it is turned on.
See Error Code List in Service Manual of machine. E05-01 is Interlock Switch Failure. Panasonic DP-C405 Service Handbook (Page 339 of 808) ' ManualsLib
11/12/2023 12:21:33 PM • Panasonic... • Answered on Nov 12, 2023
Panasonic toughbook cf-54 has password and usb not boot need password removed. cmos battery removal does not work.
only Panasonic.com can clear BIOS admin PW.. not legal here.
8/16/2023 5:52:21 PM • Panasonic... • Answered on Aug 16, 2023
Panasonic Lumix FZ28 digital camera drains battery.
I would send it in for repair. If there are 3 contact pins when there should be 4, you will need that part that holds the pins. It is unusual to have a Service manual for cameras, but here it is and shows disassembly. https://www.google.com/search?q=panasonic+lumix+fz28+repair+manual ..
7/7/2023 7:02:32 PM • Panasonic... • Answered on Jul 07, 2023
Panasonic cf-19 Enter key not working
  • Fn is locked (pressed-down) until you press another key. Use this when pressing difficult key combinations. • Popup menu icon on/off Start up the Hotkey Settings. Click [start] - [All Programs] - [Panasonic] - [Hotkey Settings]. Make the settings. [Use Fn key lock] When using an Fn key combination Press Fn once.
6/16/2023 9:14:01 AM • Panasonic... • Answered on Jun 16, 2023
Panasonic Evo54 tv old tube tv The +B voltage to line output transistor is only 45volts Plz help Red light is on and not switching on
The usual cause is leaky line output stage or transformer. Lift the line output transistor out and see if the voltage rises. If it does, scrap the TV as it is totally obsolete. If it doesn't, repair the power supply, if you can source the obsolete parts.
5/26/2023 3:15:58 AM • Panasonic... • Answered on May 26, 2023
Panasonic CF-19KHRAG2M Rugged Laptop Computer. I need a component diagram please.
Question edited for clarity, full 'make model (what it is)'. Question moved from Television and Video category. It appears you are working on the Serial Port https://www.manualslib.com/manual/304435/Panasonic-Toughbook-Cf-19khrag2m.html?page=72&term=GPS&selected=2#manual Service Manual for CF-19CHBAXBM may be close enough. https://www.manualslib.com/manual/553265/Panasonic-Toughbook-Cf-19chbaxbm.html ..
5/19/2023 4:14:01 PM • Panasonic... • Answered on May 19, 2023
In South Africa need codes for panasonic tv. I have goldstone gs40 remote
All the codes are here https://codesforuniversalremotes.com/remote-control-codes-for-panasonic-tvs/ But..... Universal Remotes? No! What is a Facsimile Remote? Your television or other device remote control fails and you think "I'll have to get a Universal Remote". In reality, no one buys universal remotes these days. They are so far back in the 1980s! You buy a 'facsimile remote' which is exactly the same as the original and requires no programming. Very often they are the same shape and the same button layout, so there is no learning transition. Google; make model (of television) replacement remote You will find somewhere like this https://www.remotecontrols.com/ or https://www.remotes.com/ For those that still want universal remote codes, the make of the universal remote is irrelevant, you only need the television make, as the codes are universal by maker. This link will find you the best websites for codes. https://www.google.com/search?q=universal+remote+codes .. Posted by ADMIN... on May 03, 2022
4/15/2023 6:20:47 PM • Panasonic... • Answered on Apr 15, 2023
My Panasonic TV model no: TH-32D310Q Green light is blinking
A blinking green light on your Panasonic TH-32D310Q TV typically indicates an issue with the TV's power supply. Here are a few steps you can try to resolve the issue:
Unplug the TV from the power outlet and wait for at least 5 minutes. Then, plug it back in and see if the green light stops blinking.
Check the power cord and make sure it is securely plugged into both the TV and the power outlet. If the cord is loose, try tightening it or using a different power outlet.
Check the TV's manual or website to see if there are any troubleshooting steps you can take to resolve the issue.
If none of these steps work, it may be a more serious issue with the TV's power supply or internal components. In this case, you may need to contact Panasonic South Africa for assistance or bring the TV to a professional repair shop.
4/1/2023 6:12:39 PM • Panasonic... • Answered on Apr 01, 2023
Panasonic KX 7730 error in the right upper with led right and message appear on screen "Mem. Msg. Escaurita" after "Urb. Non. Assegn.
The likely cause of this message is a defective memory card or a corrupt file on it. Try replacing the memory card or reformatting it, and then restarting the machine. If that does not resolve the issue, contact the manufacturer for assistance.
2/23/2023 12:49:46 PM • Panasonic... • Answered on Feb 23, 2023
Panasonic TC-P50S30 VIERA 50 Class 49.9 Diagonal S30 Series Plasma, Aspect Ratio 16:9, Native Resolution Number of Pixels 2073600 1920 x 1080, Moving Picture Resolution 900 lines, Shades of Gradation 6144 equivalent, 600Hz Sub-field Drive, 24p Playback 2:3, De Logo
14 questions posted
Top Panasonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Panasonic Computers & Internet
Most Popular Question
am getting 14 blink code panasonic tc
  • Computers & Internet
