20 Most Recent
HHP Hand Held Products IT3800LR-12 Barcode Scanner Questions & Answers
Double scans
Its your software, try to reset the PoS software you are using. you could also first test by using note pad or any text editor. with your barcode scanner connected, close all open applications, open a black note pad and scan to the note pad. check if it does double scan still to confirm.
Regards
I can't programmed my IT3800LR
Jaquino, there is a programming bar code to reset the device to factory settings in the user guide. I know you said that it is reading other bar codes like they are not programming bar codes, but have you tried this bar code? Usually it works, even when the device is totally hosed, unless there is some kind of hardware failure.
Here's the link to the Quick Start from the company website:
http://www.handheld.com/download.aspx?download=/data/f9e7f996-9ecc-4f49-b604-32fbd754085d.pdf&filename=3800+Linear+Series+Quick+Start
The factory reset bar code is on printed page 4 of the PDF document.
