20 Most Recent Apple iPod touch 64GB with FaceTime Questions & Answers
Apple ipod 60GB model A1136 How can I play a movie on a TV
what format do movies need to be played on a Ipod classis model a 1136, it seems that mine doesn't accept ie. Youtube movies ...?
3/7/2024 1:54:43 AM • Apple Audio... • Answered on Mar 07, 2024
Beats Solo 3 wireless headphones can't hold the charge of a full charged battery. It's not a battery fault because a few days replaced it by a brand new one and I have the same problem.
Could you please add a picture of the components which are heating up crazily? There is a good chance these are voltage rectifying chips. Those will boost the voltage up or buck the voltage down to a specific number. Please add the picture so I can take a look at which components they are.
9/13/2022 8:23:16 AM • Apple Audio... • Answered on Sep 13, 2022
tip
Pairing Apple Air Bud Clones
If they are the Apple ear bud clones, there is a technique to get them paired and both working. You get the left to work, or you get the right to work!!
  1. Tell your phone to Bluetooth Search.
  2. Press the On button for one earbud.
  3. Press the On button on the other earbud and then double press the button on that one.
  4. Go to the phone. At the bottom of the Bluetooth list you will see two numerical entries that say paired. Ignore those. In the top list of Bluetooth items you have used before, you will see one that is the Friendly Name for your earbuds (mine says i12-TWS). Press that once and it will change to connected. Then both will be connected.
It took me weeks to find this out.
3answers
Capacity to download audiobooks
Hi there PatAccording to the user manual for the ipod nano 5th generation you can add audiobooks. These directions are directly from the manualIn itunes, select ipod nano in the devices list and click on the music tabThen select Sync Music, and then do one of the following:(a) Select "Entire music library"(b) Select "Selected playlists, artists, and genres," and then select Audiobooks (below Playlists).Click Apply.The update begins automatically.Hope this helps.
1/18/2022 3:48:39 AM • Apple Audio... • Answered on Jan 18, 2022
3answers
What are MOV files for?
MOV is a common multimedia format often used for saving movies and other video files; uses a proprietary compression algorithm developed by Apple Computer; compatible with both Macintosh and Windows platforms.To play a MOV file, use this playerhttp://movplayer.net/
12/28/2021 3:14:19 AM • Apple Audio... • Answered on Dec 28, 2021
Why is the audio on vizio tv not working?
Press the Menu button on your VIZIO remote. Use the arrow keys to highlight 'Audio' or 'Audio Settings' and press the 'OK' key on the remote. Make sure it says 'On' next to the TV Speakers setting. If it states off, press okay to choose 'ON'.https://downloadnox.onl/ https://vidmate.vet/ https://vlc.onl/
8/10/2021 4:04:41 PM • Apple Audio... • Answered on Aug 10, 2021
2answers
How do I delete songs from my ipod from a usb port on a computer?
First plug your i-pod 1st generation into my usb port on your computer.Then download and install Sharepod. when the it appears right click the selected song and delete it, in the main menu
2/13/2020 9:17:00 AM • Apple Audio... • Answered on Feb 13, 2020
When I use my Apple TV 4 through my htr-5940 Yamaha using the AHLTV app I have intermittent sound and the receiver shows a CHECK SPKR WIRES message. HELP!!!
Hi Vicki Greenwood, so your Yamaha tells you, check that your speaker cables are not damaged or improperly connected On the other hand, it controls the level of signal that is input from the Apple TV, it may be overmodulating Take the tests and comment Regards Franco Dosil Hola Vicki Greenwood, por lo que te indica tu Yamaha, comprueba que los cables de tus bafles no esten da?ados o mal conectados Por otro lado, controla el nivel de se?al que le ingresa desde el Apple TV, puede estar sobremodulando Haz las pruebas y comenta Saludos Franco Dosil https://usa.yamaha.com/files/download/other_assets/2/319822/01_om_htr-5940.pdf
10/6/2019 7:09:53 PM • Apple Audio... • Answered on Oct 06, 2019
2answers
There are two ways to delete music from your iPod. The first is to delete songs in your iTunes library and have iTunes sync your library to your iPod automatically when you plug your iPod into the computer. The second is to manually delete music by resetting the options to a manual setting and deleting music directly from your iPod without affecting the songs in your iTunes library. Follow these steps to delete music from your iPod. Open up iTunes by double clicking on the "iTunes" icon. Go to "Library" on the far left side of the screen. Click "Music" from this list, which will bring up all your music on the main part of the screen. Choose a song you would like to delete from the list and right click on it. Click "Delete" from the drop-down menu that appears to delete your song. Go to the bottom of the left column on the screen to "Playlists." Click on one of your playlists to bring up the list of songs in the list. From there you can delete a song on the list. Connect your iPod to your computer. The iTunes program will automatically sync your iPod to whatever you have changed in your iTunes library as long as it is set to the default settings. Manually Delete Music Connect your iPod to your computer. Open up iTunes. Choose the third option in the "Options" menu called "Manually manage music" by checking the box next to it. It will ask you if you are sure you want to manually manage music on your iPod. Click "OK." Go to "Devices" on the far left column on your screen. You will see your iPod's name directly underneath that with an arrow pointing to the right. Click on the arrow, which will cause it to rotate until it is pointing downward and a drop-down menu will appear with all your songs listed. Click on a category or playlist, which will bring up all the songs in the list in the main section of the screen. Choose on a song listed that you would like to delete and right click on it, then click "Delete" from the drop-down menu that appears to delete your song.
9/16/2019 6:58:15 AM • Apple Audio... • Answered on Sep 16, 2019
4answers
How To rip Blu-ray DVD Format? How To Convert
I think you can try Leawo Blu-ray Ripper, it is an all-inclusive tool for handling both Blu-ray and DVD discs. The ability to decrypt Blu-ray disc with MKB level ranged from 0 - 21 and with AACS and BD+ protection has made it the strongest ever to rip Blu-ray videos.
Here is the full guide to tell you how to rip blu-ray or DVD to iPod video.
8/14/2019 6:01:31 AM • Apple Audio... • Answered on Aug 14, 2019
Lightning struck my home. All of my receivers are powering on but are not transmitting any audio or video signals. my DVD player and my Apple TV is also not working. what do i do ?
Unfortunately, lightning may have damaged your equipment beyond simple fixes. Most likely the sensitive circuits inside are blown, and you may need to replace them all.
5/24/2019 10:24:29 PM • Apple Audio... • Answered on May 24, 2019
Ipod 7th gen won't charge. The screen flashes with the apple log when charging
Did you try a different charger and charging cable? if you did, then probably the buck/boost converter connected to the battery is broken. This is an advanced repair to do, but you can try to look on ebay for a charging port for your ipod model.
1/15/2019 6:12:07 AM • Apple Audio... • Answered on Jan 15, 2019
I have an AVOL ALT3210M that I use with AppleTV 2. My speakers no longer work, either with my HDMI or s-video connections (DVD). On my Apple TV under speakers it only shows Apple TV.
Just for clarification and to remove it from the unawnsered list: Problem is solved by restarting.
1/15/2019 6:01:49 AM • Apple Audio... • Answered on Jan 15, 2019
How do I adjust the time on my 2008 Ipod model # A1213 apple Ipod 32GB?
Go to settings -> Time and language, disable automatic time sync and click then on "set time"
1/15/2019 5:57:32 AM • Apple Audio... • Answered on Jan 15, 2019
2answers
Can you give me free download iOS 11.0 on my apple iPod
There is always an aptoide store which will help you download most of the premium/paid apps and games for free on your iPhone and iPad. https://aptoideios.info/
11/17/2018 10:52:40 AM • Apple Audio... • Answered on Nov 17, 2018
I want to unlock my Apple iPod
notify provider or apple
6/17/2018 12:24:46 PM • Apple Audio... • Answered on Jun 17, 2018
Apple iPod touch 64GB with FaceTime Logo
2 questions posted
Popular Products
Top Apple Audio Players & Recorders Experts
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
ZJ Limited
ZJ Limited
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
View Most Popular
  • Apple Audio Players & Recorders
Most Popular Question
apple ipod 60gb model a1136 play movie
  • Audio Players & Recorders
