20 Most Recent
Sanyo vpc-s1415 - Vpc-s1415 14.0 Megapixels Digital Camera Questions & Answers
I push the button but it wont take a picture
Did you try it like it is said in the manual? press the button half till the camera is focused and then press the button completely down?
Don't expect the camera to shoot with the same speed as a camera with film did. Give it some time to focus and everything will be fine (I hope)
If not let me know.
Contact lense
You can check one of these special contact lens cleaners below:http://www.goodguide.com/categories/152676-contact-lens-cleaners##products
Lense doesn't retract
Common faults for this:The lens motor is defective, lens gears jammed. Fix is lens unit replacement. The lens servo drive circuit is not functioning. Fix is to replace the circuit board that contains the lens servo control circuits. The connector assembly between the lens is not making proper contact, or the lens wire assembly is defective. Fix is replacement of the cable and connectors if applicable in the particular model. If the connectors on the circuit board or lens are defective, then the appropriate unit must be replaced. No power is going to the lens unit, and or the lens servo circuit. Fix is replacement of the drive circuit board, or the power inverter if it uses a separate feed for the lens only. Generally, with these low cost cameras they generally do not pay to service out of warranty. The service cost can approach the cost of replacing the camera. Common causes of failures in these cameras is from water (getting wet), or dropping, or rough usage. Jerry G.
Sanyo VPC-T1496 Battery issues
Talk to Kastar and tell them there battery messed up your camera. I am assuming the camera was working OK when you got it.
