20 Most Recent
Razer RZ01050300 Mouse Questions & Answers
Mine is Razer Lachesis Mouse
This can be a complex problem, First try plugging the mouse into a different computer to see if the problem is only with the current computer. After that try going to Razers website and downloading device drivers for windows (or mac). Hopefully that will allow your computer to detect the mouse. Also make sure that the laser for the mouse is working (it may be hard to see on performance mouses, but look carefully for a red dot).
Mouse pointe not move
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Hi i have recently bought
make sure you have the correct mouse selected control panel mouse hardware
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty or you
might have to uninstall the drivers then reinstall the drivers
control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot or select properties under driver you can update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
My Razer mouse is sticking all over the place,
assuming it is dirty inside . look on the bottom of the mouse for a screw , unscrew it and take apart mouse remove ball and see if there is dirt or debris built up on any of the three rollers , if so remove with fingernail or wet rag . put back together . if this does not fix it go to start panel in windows and then control panel click on mouse then see if all the settings are correct usually pointer options tab at the top is where to start .
Razer wireless mouse wont work in PC mode on mac
I think you are using a Non- Windows specified Driver. If yes then you will have this problem. Try a Windows Driver ( the Windows which you have ). Also if it doesn't solve, check that is the Program is running in the compatibility mode of your windows.
Thank you, Have a nice day.
Middle button not functioning
Hate to tell you but it is a common thing that goes wrong with Razers, inside the mouse there is a rod that is connected to the middle mouse button, this is also connected to the engine that tell the mouse what you are doing, after to much use this engine simples dies and forces you to buy another mouse
Razer Lachesis dont turn on after reboot???
YOUR USB ROOT HUB MAY BE IN HIBERNATION. GO TO DEVICE MANAGER IN CONTROL PANEL AND RIGHT CLICK ON EACH USB ROOT HUB ....GO TO PROPERTIES AND UNCHECK ENERGY SAVING MODE.....ALSO CHECK POWER OPTIONS IN CONTROL PANEL AND UNCHECK HIBERNATION OPTION.....THIS SORTED OUT MY RAZER LACHESIS THAT WAS NOT BEING PICKED UP BY WINDOWS..
Razer Lachesis moves without touching
Greetings, I had this problem occasionally as well. Except I have the Habu instead of the lachesis. I fixed mine however, when I saw my cordless (yes, i keep it plugged in at the same time) Had been knocked off its charger by someone. When I replaced it (preventing outside interference form it) The problem with my migratory cursor was fixed. I see this was posted a couple months ago, but hopefully this helps some.
Razer Death Adder moves by itself
Could there be some dust inside the laser eye or something else. On what surface are you using it. Try it on a blank piece of paper
