20 Most Recent
Tasco NV200W Monocular Questions & Answers
WHAT BATTERY
Hello, most of these NV monoculars uses CR123A. It a 3 volt battery about 1/2 size of AA and its girth is a little larger. Aslo, some use two AA batteries. Little information here. Some of these night visison monoculars and binoculars that sealed for water infiltration are epoxy together. stewbison
Can i have a wiring
Hello, I don't understand. Yes there are a few wiring connections inside this NV200 monocular.
Kent, I will need to know what the problem with your NV monocular before I can properly diagnosis your NV problems. There just to many things that can happen to these NV devises. stewbison
Unit will not turn on. Changed batteries
For batteries to get hot they must be in a dead short situation.
Have you put batteries in the wrong way around before you have realised and then put them into the right positions
If the power circuit of the monocular has not got reverse polarity protection you can short out components which will give you the problem you have now.
Only solution is to get someone to take the board out to see if it is cooked
How do you look though and see Star . Tasco 45-060525 does it need a light or something?
No, they only collect the light from the stars or the moon. First you have to be in a place with very little light pollution. I live in a city and haven't seen stars here for 17 years. Also you must let your eyes acclimatize to the dark.
In reality, this telescope will only be suitable for the moon, but the moon will fill the Object lens and show great detail. You may also see some planets if you can find them, but generally it turns a small speck of light into a larger speck of light. The International Space Station should also show well.
Here is your manual
https://manuall.co.uk/tasco-46-060525-telescope/
2/20/2022 1:23:10 AM •
Tasco Optics
Answered
on Feb 20, 2022
