if your computer came with a motherboard disc the sound drivers could be on itclick start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstallclick start control panel sounds and audio,volume,advanced,speakers make sure you have selected the (((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settingstherealsoclick start control panel sounds and audio devices select advanced there might be a tick in the mute box untick itclick start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might checkthe speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is goodtry cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
i was wondering are tying to install additional partition or you wanted a dual boot? or simple want to install WVista completely from scratch? normally what you need to do is hit F12 go to boot menu then your bottable CD should be on the CD/DVD drive already and re-format your hard drive...
For the Seagate hard disk model ST3120827AS, the TVS diode is typically located on the circuit board (PCB). TVS diodes are designed to protect electronic circuits from voltage spikes and transient events. They are usually small, with two leads, and look like small cylindrical or rectangular components.To locate the TVS diode on the circuit board, you may need to refer to the hard drive's datasheet or schematic diagram, if available. Additionally, you can try searching for online resources or forums where individuals share information about hard drive components and their locations.Regarding the Cisco Nexus Network Switch , it's important to note that specific details about the internal components, including the location of TVS diodes, may be proprietary and not readily available in publicly accessible documents. For detailed information about the switch's internal components, you may need to refer to Cisco's official documentation or contact Cisco's supporthttps://www.serverblink.com/n3k-c31108pc-v-cisco-nexus-network-switch/
Try downloading TESTDISK and see if the drive is detected on the List within TESTDISK. If it is then you may be able to restore the boot sector within TESTDISK.
You will need an external Hard drive adapter case.
This will probably come with driver disk.
If already and external drive it may have internal firmware which talks directly to the PC.
Just install drivers, if any, and plug unit in.
Follow screen prompts.
You do not say what OS you were installing, and Windows limits what you can do with the hard drive during installation.
As you have found out, any power interruption during an installation will likely corrupt the process and make the system unbootable.
If you can restart the install at the very beginning that may work for you. However, I believe the simplest fix will be to use a live system bootable disk and erase the corrupted partition table on the drive then restart the install as if it were a brand new hard drive.
For that type of recovery I use gparted, which can be downloaded for free from http://gparted.org/livecd.php
Gparted live can be used on CD, hard disk, USB, or even pxe boot. I would delete all the existing partitions that were created during the failed install, then restart the install from the very beginning as if it were a new disk.
The hard disk must have crashed and only professional data recovery service providers can retrieve data from the hard disk. It will cost money and if the data is extremely important then only you should opt for data recovery.
You mean "lost" photos? or I don't understand your question. If lost, there are a number of "free" recovery software solutions as well as purchase type solutions. Otherwise, tomshardware.com has very good answers.
I understand the value of the files that resides on the disk:) Yes! It is possible that harddisk may back to life by replacing the logic board but of the same model or part number. If it is not possible by replacing logic board due to other defects such as head crash and spindle drive motor opened/shorted, there still a big chance to recover depending how you value the data on it by contacting international Seagate Data Recovery support service with considerable service fee. Hope this helps.
