20 Most Recent
Briel Domus Due Espresso Machine & Coffee Maker Questions & Answers
Leaks From Filter Gasket
Sounds like you might have coffee oil build up. I would suggest soaking the Brew Head Screen and filter holder in a coffee oil remover by
www.urnex.com or dezcal. Remove the screw if your filter basket has one. For home use it would be good to clean this every week or so. You can email me for more info:
[email protected]. You also might just try purchasing a new filter basket (along with cleaning the Brew head screen and new basket).
Further technical info can be found at:
Electra-Craft
41 Woodbine St
Bergenfield NJ 07621
phone 201-439-1700
fax 201-439-1701
[email protected]
www.electra-craft.com
I need a printable manual
yes, they make it pretty hard to find but I eventually found it on the Breil website, this covers several machines including the Domus Due:http://www.brielbg.com/pdf_instrukcii/004.pdf
Manual Briel ES161atb
Don't know about replacement parts but instruction manual can be downloaded from the website in PDF file.
LEAKING DOMUS DUE
such tools can be purchased at Ace, Lowe's or homedepot. I had to purchase one to get into my tivo and the hardest part is getting the right size. you might try taking an impression of the screw with clay or by a rubbing with pencil and paper..
Briel machine doesn't work
This might sound silly, but are you sure the water tank is well snapped into place. A strange sound does occur when the water tank is empty, but if the water tank valve is not tightly in place, it might stop the water from going through.
Espresso maker not workin properly
Your Brew Head screen and/or filter basket might be clogged with coffee oils. You can soak both pieces in a product that removes coffee oils from either
www.urnex.com or Dezcal brand. Coffee shops will do this once a day. If you have the filter basket with the screw in the middle, you will need to remove the screw and soak everything as it can clog also.
If that does not work (it should tho) you can contact the Briel service center at:
Electra-Craft
41 Woodbine St
phone 201-439-1700
fax 201-439-1701
[email protected]
Spares
Try these people
I got a new basket from them for about $6
Electra-Craft, Inc
41 Woodbine Street
Bergenfield, NJ 07621
201 439 1700
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
