20 Most Recent
Tannoy Fusion TS10 Speaker Questions & Answers
My Tannoy TS10 keeps blowing fuses and I get no
Something inside it is acting like it was just a piece of wire instead of doing it's job. That's why the fuses blow. Look at either the power supply section - transformer, diodes, voltage regulators. OR the main output devices. If they are transistors, you can test them with a ohm meter. The part will show up easy! It will be just like you had just touched the two probes together!!
Sub Hum
Was not clear .....does the sub have audio output
If not the preamp circuit is bad and this will cause the hum as well
