20 Most Recent
La Marzocco Linea Series Group 3 Espresso Machine Espresso Machine Questions & Answers
My steam wand makes my milk taste of burnt plastic.
The boiler is contaminated, you will need to descale boiler and steam valves. Then rinse thoroughly about 5 times. The easiest way to check for this is to draw water from the tea spicket and check for smell and sediment. Something on the bottom of the boiler is being lifted when the machine fills and when it is heating. If there is a filter system on the line check to make sure it was changed recently.
I have detergent solution in the coffee and steam
Then you will need to flush the boilers out and rinse, its easy, just takes alot of time. First turn the water supply and the machine off and let cool, then back off the screw in the knob a few turns and pull off knob. Then remove the screws holding the front panel to frame. There's about 5 of them. Note the valves under the boilers with the red or black handles. They are usually in the middle. Use this valve to remove the water in the boiler, then fill boiler and rinse about 3 times each. Then reassemble and you should be good to go.
Zero steam from steam wands.
First thngs first, make sure knob is turned to 2, then make sure there is water in the boiler, then turn machine to 0, remove back panel and reset thermostat on top of back boiler, if your machine has that feature installed. Then turn machine to 2, open one of the steam wands, If within 10 minutes boiler does get hot or there is no water bubbles, from steam wand, then the pressure stat might be damaged and needs to be replaced.
Power boiler froze and then
There are 2 boilers on these machines, Which one are you having this problem with?
I might have the tank/boiler for the group heads.
If you remove the boiler, Replace O'rings and gaskets.
I have a Marzocco Linea and need to drain the
Look at the bottom of the tank they have a red valve or a plug.
Once is off and cool down, Open the valve or remove the plug.
Open the steam valve (to allow the air in)to speed up the process.
How do I increase grouphead
To increase dispense pressure you turn the adjustment screw at the pump. When pulling a shot (use espresso) on one group the bottom needle of the gauge should read 9bars while pulling the shot.
I need to calibrate the
Press spiral button and hold for 8 secs, lights will flash, then press button you want to program when you get correct volume press stop button. Some machines need a key to program them, check to see if there is a lock on the front of machine. If you have the model with the cronos pads you do not have to worry about a lock.
