20 Most Recent
VeriFone 900 Printer Questions & Answers
Printer begins to randomly feed paper and will
It's because of power issue
You have to disconnect all the cables and clean make sure no dirt
Connect the printer first and power up the register
If still the problem persists
you need to replace some files by doing a dialin
Spits out extra paper
This is a VERY common problem for these printer models and occurs as the terminal ages. This is caused by a faulty paper feed sensor and needs to be sent in to an authorized service center to have the sensor replaced and paper feed adjusted.
Sorry it wasn't better news, but at least it can be repaired fairly inexpensively. Good luck!
Verifone 350
If you are using the PrintPak 350 printer, you can use either a standard serial printer cable to connect to your computer, or use a serial-to-usb adapter cable to plug it into an open usb port. Once plugged in, your computer should assign a Generic printer driver to the device automatically.
Just cant get it to print the receipt...
You can connect it two(2) ways...
1) use a standard serial cable (printer cable)
2) purchase a USB-to-Serial adaptor and plug it in to an open USB port.
Either way, once it is connected the system should see it and assign a generic printer driver.
Hope that helps! Good luck!
Printer will not print receipt.
- Unplug
the printer cable from the computer.
- Unistall the
printer drivers from Device manager and also unistall the all the printer
appications
- restart the
computer
- try to download
drivers from the website
- after installing
drivers and software it will ask you to connect the printer.
- then you can
connect the printer and and try to Print the test page.
How to connet to the computer and how to find drivers
If your printer has a "Centronics" printer connection (a large 2"wide connector) and your computer has only USB connections, you need a "USB to Centronics" printer cable. Easiest way is to buy one from the internet. Use your favourite search site or EBay to locate and purchase. Most computer stores will not have them in stock.
Hellp me to downloud drievr
Go to the Verifone website, look up your printer, and you should find what you need in your Support section.
Have verifone 801 printer - prints game and fish
NOTE: The inside cover of the printer has medialoading instructions for vendors.
- Open the lid of the printer by pressing in on the two (2) Blue buttons on both sides of the printer, and lift upward.
- Press down on the Green Printhead Latch, and raise the Printhead Carrier assembly to a vertical and locked position.
- Remove the Ink Ribbons (Supply and Take-up Hubs/Spindles) from the Printhead Carrier by pushing in, and lifting up.
- Slide both ribbons off the hubs, and discard them into the trash.
- Slide an empty core onto the take-up hub. (The attached new roll of ribbon includes a new supply hub.)
- Unroll a 1-foot length of ribbon. (The foiled side will need to be facing the Printhead and rollers.)
- Insert the supply hub/ribbon into the rear spring-loaded spindle.
- Starting from the back of the Printhead Carrier, thread the take-up hub/core in between the black guide bar and the two (2) aluminum rollers.
- Continue past the Printhead, and over the 3rd aluminum roller.
- Insert the take-up hub into the spring-loaded spindle 'star' hole.
- Position the license paper (media) over the rubber roller to the edge of the opening with one hand.
- With your other hand, lower the Printhead Carrier to its locked position.
- Close the printer lid.
