20 Most Recent
Sony Str Da333es 5.1 Channel 400 Watt Receiver Tested Works Great Questions & Answers
SONY CX330 camera shutting down
Why do they need to be turned on all the time? If your using them as security cameras they are not designed for that job. The 330 could be overheating because of the constant use. Some cameras have a built in 'Overheat' switch which could be switching it off.
These cameras are designed for short periods of use, recording things like parties and holiday trips. How old are these handycams? These do get old and the technology in them can wear out if in constant use.
Sony cfd-s70 Will Not Read CDs
There are a few possible causes for a Sony CFD-S70 CD player not reading CDs. Some possible issues include:
- Dirty or damaged CD: Make sure the CD is clean and free of scratches or damage.
- Dirty lens: The lens that reads the CD may be dirty or dusty. A cleaning disc can be used to clean the lens, or you can use a soft, dry cloth to gently wipe it clean.
- Faulty lens: If the lens is faulty, it may need to be replaced.
- Faulty CD mechanism: If the CD mechanism is not working properly, it may need to be repaired or replaced.
- Power Supply Problem: Make sure the power supply is connected and the power outlet is working.
- Firmware issue: A firmware issue could prevent the CD player from reading CDs. You should check the Sony website to see if there are any firmware updates available for your specific model.
If the problem persists after trying these suggestions, it is recommended to take the device to a professional repair service or the nearest Sony Service center.
Sony TRV 740 E Fehlercode C:31:40
Der Fehlercode C:31:40 bei Sony Camcordern deutet auf ein Problem mit dem Motor des Kassettenfachs hin. Es kann sein, dass der Motor blockiert ist oder dass es ein Problem mit den Sensoren gibt, die den Status des Kassettenfachs ?berwachen. Um das Problem zu beheben, k?nnen Sie folgende Schritte ausprobieren:
- Entfernen Sie die Batterie und das Netzkabel des Camcorders und lassen Sie das Ger?t f?r einige Minuten ausgeschaltet.
- ?berpr?fen Sie das Kassettenfach auf lose Teile oder Fremdk?rper, die m?glicherweise blockieren k?nnten.
- Versuchen Sie, das Kassettenfach vorsichtig zu schlie?en und zu ?ffnen, um zu sehen, ob dies das Problem l?st.
- Wenn das Problem weiterhin besteht, k?nnen Sie versuchen, das Kassettenfach mit Druckluft zu reinigen, um m?gliche Blockaden zu entfernen.
- Wenn alle diese Schritte fehlschlagen, kann es ein mechanisches oder elektronisches Problem sein, das eine Reparatur durch einen qualifizierten Techniker erfordert.
Es ist auch m?glich, dass das Problem durch eine defekte Cassette verursacht wird. Wenn m?glich, versuchen Sie, eine andere Cassette auszuprobieren, um zu sehen, ob dies das Problem l?st. Wenn das Problem weiterhin besteht, liegt es h?chstwahrscheinlich am Camcorder selbst.
Sony Playstation 3. Infamous intro doesn't load
- Restart the console: Sometimes, restarting the console can resolve software issues and help the game load properly.
- Check for updates: Make sure you have the latest firmware installed on your PlayStation 3, which can be done by navigating to the "Settings" menu and then to "System Update".
- Check the game disc: Make sure the disc is clean and free of scratches or damage. If the disc is damaged, it may need to be replaced.
- Reinstall the game: Try uninstalling the game and reinstalling it from the disc. This can help resolve any corrupt data that may be causing the issue.
- Try a different game: If the issue persists, try playing a different game to see if it's specific to Infamous 2 or if it's a general issue with the console.
