20 Most Recent
Hotpoint 23 in. BFI62 Built-in Dishwasher Questions & Answers
Wash cycle not completed
Lights 1 and 3 indicate that the filters are blocked.
Check water flows through the spray arms onto the cutlery - indicated by wet cutlery.
If dry - recirculation pump is probably blocked
Powdery **** left on dishes after wasing
If you live in a region with hard water, dishwasher detergents don't work very well anymore. The govt outlawed phosphate as an ingredient in detergent. Weird but true. Look at this map to see if you have hard water. If so, try cloudydishes.comhttp://www.citriclean.net/why-citriclean/
My Hotpoint BFI680 dishwasher trips
This is caused by having a dryer element, if you are able to get to the back of the element look for where the wires connect to it, I am almost positive the element is bad, always turn off the power when looking at any electrical unit to service , if not sure use a tester, you should have zero volts at the connection box near lower right hand side near floor. you can get this element from here if you have all the information on this unit,
http://www.appliancepartspros.com/ you can also email me at
[email protected] good luck
Items in top basket have
I
have an older dishwasher also and recently my wife also complained
about it not cleaning right... so me being the man I am tried in vain
to clean the things... Bought new spray arms online and installed
them in minutes...now the thing works like new... However I have also
found that if the heating element goes bad then that also can mess
things up bad... So I would buy new spray arms, and also check out
the heating element to make sure it is working... Here is a tip that
will help you with the online buying...
Dishwasher
Spray
Arms not Spinning
How
to Buy Appliance
Parts Online
A
bad heating element causes many problems in
dishwashers...
Dishwasher Problems The Heating
Element not Working
Dishwasher
Maintenance
Dishwasher
Residue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give
it a go and see how simple it was. thanks Ronnie " -
ronnieshomes
