20 Most Recent Hotpoint 23 in. BF41 Built-in Dishwasher Questions & Answers
My BF41 Hotpoint integrated Dishwasher seems to
I've had this issue with my thermal fuse blowing. If the water gets too hot, this will trip. If you have a meter and know how to handle yourself around electricity (power off and verified), then you can pull the liner out to get to the electronics. (I don't know the exact method for the Hotpoint). Follow the power lines and you'll find the fuse. Mine has two wires connected to tabs on a little card. If the fuse shows open on the meter, then you can get another for just a few bucks off your favorite auction site, or local appliance parts store (a few bucks more, but immediate delivery). If you have the hot water heater temp high, then you might want to make sure you don't use the "heat water" function, otherwise the fuse will blow again.Please let us know if this helps, it will benefit others in your situation.
1/4/2018 6:18:43 AM • Hotpoint 23 in.... • Answered on Jan 04, 2018
0answers
0answers
0answers
Spring mechanism is broke. As
If you need to replace the spring mechanism, go to Sears's website and access the parts direct section. Here you can enter your make and model. It will show you a cutsheet with part names and numbers. Order the parts you need from there.
9/4/2011 7:08:26 PM • Hotpoint 23 in.... • Answered on Sep 04, 2011
0answers
Loud noise from dishwasher door. then no
It sounds like you may have a broken door spring. You will have to take off the bottom panel and with a flash light you can look to see if one of the springs came off or broke. If the spring is broken you will have to purchase a new spring and replace it.
2/25/2011 8:12:20 PM • Hotpoint 23 in.... • Answered on Feb 25, 2011
3answers
Soap film left on dishes and it won't come off aft...
Check the rinse aid dispenser!
Check water quality and the soap you are using.
11/15/2010 9:41:33 PM • Hotpoint 23 in.... • Answered on Nov 15, 2010
2answers
Dishwasher element and thermostat
Check with multi-meter for power on heating element's tags. If it does get power, you should replace the heating element. In case of no power- you should replace the thermostat. Good luck !
12/4/2009 10:08:34 PM • Hotpoint 23 in.... • Answered on Dec 04, 2009
Dishwashing liquid was placed in the jetdry compartment
hi thanks for the question no its not ruined . just keep filling using vinegar , that will cut down the suds .do it 3 or 4 times problem will go away thanks the appliance doc
9/27/2008 3:28:59 PM • Hotpoint 23 in.... • Answered on Sep 27, 2008
Top basket spray not working
did you solve this problem mine is doing the same?
7/18/2008 1:17:25 PM • Hotpoint 23 in.... • Answered on Jul 18, 2008
7answers
Continuous rinsing
Put 2 tablespoons of oil into the water at the bottom of the dishwasher it will help break up the suds. Sprinkle as well ordinary table salt liberally across the suds to disperse them. Try to drain the unit as much as possible, soaking up any residual water or suds with a dry towel. Let the machine fill again, and repeat the process if necessary. Good luck !
4/8/2008 2:43:18 PM • Hotpoint 23 in.... • Answered on Apr 08, 2008
Dishwasher
Let the suds die down then pour in about 1/4 cup of vegetable oil. Start the machine and let it run a few minutes then open the door and see if it is still sudsing. This will usually kill the suds. Some times I have to repeat again but not usually. Drain the water out and run through a short cycle with regular detergent and you should be good to go again.
Mike
1/7/2008 11:38:04 PM • Hotpoint 23 in.... • Answered on Jan 07, 2008
Dishwasher is stuck on the rinse cycle
make sure the float or metal probes in the unit are clean.they sense water and if anything is on them it will cause a malfunction in the unit.
8/28/2007 12:41:13 AM • Hotpoint 23 in.... • Answered on Aug 28, 2007
Dishwashers Logo
28 questions posted
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Dishwashers
Most Popular Question
dishwasher
  • Dishwashers
