20 Most Recent Hotpoint 23 in. BFV62 Built-in Dishwasher Questions & Answers
Left side first and second light flashing
I think I've seen this one on a similar dishwasher. You have an internal leak. Because yours is built in it's not easy to check but If you can lift it out and angle the machine forward about 45 degrees - you will need some towels! ... This might be a temporary cure but I ended up sealing the cabinet by opening up the case and using a mixture of silicon sealant and duct tape.
3/10/2014 1:35:27 PM • Hotpoint 23 in.... • Answered on Mar 10, 2014
My hotpoint dishwasher wont go past filling up,
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble No Water entering Dishwasher
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
8/19/2010 10:53:00 AM • Hotpoint 23 in.... • Answered on Aug 19, 2010
Hotpoint dishwasher
Check your heating element..
Dishwasher2_bing.gif Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher2_bing.gif Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Asker's Testimonial " expanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
8/3/2010 4:50:01 PM • Hotpoint 23 in.... • Answered on Aug 03, 2010
Hotpoint dishwasher mod BFV620W starts then pumps
go to hotpoint web address and they will tell you.i would suspect main circuit board.adrian,,,,
7/14/2010 3:58:02 AM • Hotpoint 23 in.... • Answered on Jul 14, 2010
Have a hotpoint aquarius dishwasher Won't work powers up Red light comes on with salt 2 nd red light come on showing X What is the X? Please
Here's what you can do to address this issue:
  1. Check the Salt Level: Ensure that the salt reservoir is filled with dishwasher salt. The dishwasher needs salt to soften the water and improve the cleaning performance. If the salt level is low or empty, refill the reservoir with dishwasher salt.
  2. Check the Salt Dispenser Cap: Make sure that the salt dispenser cap is securely closed. If it's not closed properly, it can cause the "X" symbol to appear on the display.
  3. Reset the Dishwasher: Try resetting the dishwasher by turning it off at the mains power supply for a few minutes, then turning it back on. This can sometimes clear error codes and restore normal operation.
  4. Check for Blockages: Ensure that the salt dispenser and its inlet are free from any blockages or obstructions that could prevent salt from dissolving properly.
  5. Consult the Manual: If the issue persists, refer to the dishwasher's user manual for troubleshooting steps specific to your model. The manual may provide additional information about error codes and how to resolve them.
If none of these steps resolve the issue and the "X" symbol continues to appear on the display, it may indicate a more significant problem with the dishwasher that requires professional diagnosis and repair. In such cases, contacting Hotpoint customer service or a qualified appliance technician for assistance is recommended.
2/20/2024 10:45:42 PM • Hotpoint... • Answered on Feb 20, 2024
Hotpoint ariston wnf722uk delay start button will only go up to 2hours the delay start button on a Hotpoint wmtf722uk
Each time you push delay, it should add 2 more hours. If not, it will only delay for 2hours.
12/11/2022 8:22:27 PM • Hotpoint... • Answered on Dec 11, 2022
Model hotpoint FDL570 dishwasher Trying to
I have same issue, have just worked out that: 1=Intensive 2=Normal 3=Daily 4=Prewash 5=Eco
2/14/2022 10:32:14 AM • Hotpoint... • Answered on Feb 14, 2022
I have hotpoint intergrated dishwasher model LTB4M116. Recently it has started to turn itself off.
Check the leak tray inside the base of the machine and see if there is water in there. There is a sensor to detect small leaks.
1/10/2021 6:15:19 PM • Hotpoint... • Answered on Jan 10, 2021
Hotpoint 23 in. BFV62 Built-in Dishwasher Logo
22 questions posted
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Paul Carew
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Hotpoint Dishwashers
Most Popular Question
left side first second light flashing
  • Dishwashers
