20 Most Recent
HP LASERJET PRO M1132 MFP Questions & Answers
Error E0 on laserjet m1132 mfp how to clear it
Hi, the error E0 is for a paper jam, please make sure your laserjet M1132 paper tray is not to full. You can also do a power reset by..... 1) disconnecting the power cable from the back of the printer........ 2) disconnect the power cable from the wall outlet. 3) Wait up to 10 seconds and reconnect the power cable back to the wall outlet first, followed by the back of the printer. 4) Turn On the printer again.
Connect your printer directly to a wall outlet. (don't use a power hub or a surge protector)
??Here is a screen grab from the manual. If you need the who manual as PDF replay. Or if you have it, please read pages 189-210+.
Unable to print and make photocopies
when you try to print does it come up with any error message?
or does it get sent to the print spooler and then lost in cyberspace?
or does it get to the printer and then the printer says no?
for the error message follow what it says so if the error is no connection check that the wires are attached. if it comes up with an error code look it up on the HP website.
if it gets lost in cyberspace try reinstalling the printer with an updated driver.
and finally if it says no go to run and type services.msc and scroll down the list till you see print spooler if it says it is stopped start it and try again, if it still doesn't work try updating the firmware
