20 Most Recent
PC Chips M861G Motherboard Questions & Answers
Iam having a pcchips m861g mainboard,and the
Its settings in the bios. Press DEL or F2 at startup and look for something like drive configuration in there and set SATA to enable. Most boards have this turned off by default. Cheers from Scott
I want to conect aux ports
get a mini jack to 2x rca cable then plug the mini jack in to your speaker out, the green port on you sound card, and the rca's into the device you want to play to
What is embedded system?
- An embedded system is a computer system with a dedicated function within a larger mechanical or electrical system, often with real-time computing constraints. It is embedded as part of a complete device often including hardware and mechanical parts.
read all about it.
Embedded system
3/6/2024 4:40:49 AM •
PC Chips...
Answered
on Mar 06, 2024
I have a pcchips p21g v1 motherboard, but it wont
Is that one of the PCChips boards that has a jumper to enable/disable writing to the BIOS (Basic Input Output System? If it has a hard drive in it, disconnect or remove the hard drive, and then reset the BIOS, by removing the BIOS battery for 5 minutes, then put the (good?) battery back in, and boot it up without any hard drive. I have seen such behavior before, due to malware such as TDL4, and also "BadBios!" Those malware systems can OVERWRITE any unprotected BIOS with modified code!
4/26/2017 8:05:43 PM •
PC Chips...
Answered
on Apr 26, 2017
Emx 945gc 1333
http://www.free-4all-download.com/downloadnow/download+emaxx+emx-mcp61M2-icafe+v2.0+driver+free+download
5/21/2014 6:12:29 AM •
PC Chips...
Answered
on May 21, 2014
Manual for pc chips a13g+v3.0
here it is http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?CategoryID=1&DetailID=402&DetailName=Feature&MenuID=46&LanID=0
5/3/2014 3:55:14 AM •
PC Chips...
Answered
on May 03, 2014
Msr905h drivers
http://softadvice.informer.com/Msr905h_Download.html
4/16/2014 10:45:48 PM •
PC Chips...
Answered
on Apr 16, 2014
