20 Most Recent PC Chips MB PCCHIPS P21G (V3.1) P4M800 775 Motherboard Questions & Answers
My system cannot detect the integrated sound card of my P21G motherboard
Try re-installing the audio driver. Here it is:http://download.ecsusa.com/dlfilepcc/sound/RealTek_v16.zipIf this is a problem from doing a clean OS re-install the don't forget to install the chipset driver first. You can get it here:http://download.ecsusa.com/dlfilepcc/usb/usb_VIA_v100.zipPCCHIPS P21G (V3.1) Complete Drivers list:http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=364&CategoryID=1&DetailName=Driver&MenuID=1&LanID=0Also, Check to make sure the Bios has the integrated sound set to "ENABLED".If you still can't get it to work. You might want to just pick up a dedicated PCI sound card for next to nothing on eBay.
6/13/2012 5:39:12 AM • PC Chips MB... • Answered on Jun 13, 2012
No display
Test all leads that attach to your hard drive including electrical extensions IDE,SATA
the leads from your "((motherboard to your hard drive))" make sure they have a secure connection and are not faulty or just replace them they might be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error If your computer came with a motherboard disc the drivers could be on it or you might have a dirty graphics card remove the graphics card and clean the socket hope this helps
7/1/2011 8:29:01 PM • PC Chips MB... • Answered on Jul 01, 2011
Need to install Video
Click start control panel administrive tools computer management device manager scroll to display adapters + to expand you might see a yellow question mark ? or exclamation mark ! or a red x right click select reinstall drivers
If your computer came with a motherboard disk the drivers could be on it or you might have to download one
cnetdownload.com on the home page you should see the download software finder under that there will be a list platform, category sub category price from the category drop down list select drivers then from the price drop down list select free or which ever applies to your need
http://majorgeeks.com/SiS_UniVGA5_Graphics_Driver_For_Windows_7_d6264.html This package consists of SiS VGA Drivers, AGP Drivers, VGA Utilities, and Installation for Windows 7. Utilities include Control Center and SiStray. The Control Center provide some settings like gamma correction, video, TV output, driver mode, screen rotate, and product information. The SiStray provide Control Center entery and some settings like resolution, refresh rate,and rotation. The Installation are capable of installing/uninstalling drivers and utilities respectively.
Supported Chipsets:
SiS671, SiS672, SiS671FX, SiS672FX, SiSM671, SiSM671MX, SiSM672, SiSM672MX the category drop down list select drivers then from the price drop down list select free or which ever applies to your need hope this helps
6/16/2011 9:42:54 AM • PC Chips MB... • Answered on Jun 16, 2011
Pc chips p21g vga drivers
Go to this link
Hope that helps.
9/24/2010 7:16:59 AM • PC Chips MB... • Answered on Sep 24, 2010
Como desabilitar video de pcchips p21g si esta
Here is some great PC solution by Some FIXYA EXPERT. Get any kinds of PC solution from bellow.
  1. Intel MotherBoard
  2. Mercury Motherboard
  3. Gigabyte Motherboard
  4. MSI Motherboard
  5. P5GC-MX/1333 Motherboard
  6. ASUS Motherboard
  7. IBM
  8. Packard Bell
  9. via
khandan18
9/14/2009 12:48:07 PM • PC Chips MB... • Answered on Sep 14, 2009
Problem installing sound drivers
  4. MSI Motherboard
  6. via
atttererawe17
9/8/2009 12:03:35 PM • PC Chips MB... • Answered on Sep 08, 2009
2answers
Drivers
Hi! Below is a link that I think should have the drivers you're looking for. Hope this helps! Hal
http://www.pcchipsusa.com/PCCWebSite/Products/ProductsDetail.aspx?detailid=364&CategoryID=1&DetailName=Driver&MenuID=44&LanID=2
6/6/2009 10:58:49 AM • PC Chips MB... • Answered on Jun 06, 2009
2answers
Usb problem on pcchips p21g v3.1
What is there to install? If I plug a usb flash drive into any of my usb's ports & than open windows explorer, I'll see the drive listed in the right panel at the end of my current devices. I can move data, music what ever back & forth. Your's should be no different. Unless you have a bad cable or your drive is a direct connect & something is wrong with its connector.
4/21/2009 11:26:41 PM • PC Chips MB... • Answered on Apr 21, 2009
Computer went dead
Faulty power supply
5/31/2008 6:59:18 AM • PC Chips MB... • Answered on May 31, 2008
2answers
P21G (V3.1) motherboad freezes and wont start
ขอ driver motherboard p 21 g v3.1 หน่อยสิ
3/26/2008 8:11:10 AM • PC Chips MB... • Answered on Mar 26, 2008
Problem with usb pen drive
Hi Vardhaman,
Is the USB port you are connecting the stick to enabled in your BIOS?. Is the Port on your Mobo or on a seperate PCI slot.
ajb2000
12/28/2007 4:00:38 PM • PC Chips MB... • Answered on Dec 28, 2007
What is embedded system?
  1. An embedded system is a computer system with a dedicated function within a larger mechanical or electrical system, often with real-time computing constraints. It is embedded as part of a complete device often including hardware and mechanical parts.
read all about it. Embedded system
3/6/2024 4:40:49 AM • PC Chips... • Answered on Mar 06, 2024
I have a pcchips p21g v1 motherboard, but it wont
Is that one of the PCChips boards that has a jumper to enable/disable writing to the BIOS (Basic Input Output System? If it has a hard drive in it, disconnect or remove the hard drive, and then reset the BIOS, by removing the BIOS battery for 5 minutes, then put the (good?) battery back in, and boot it up without any hard drive. I have seen such behavior before, due to malware such as TDL4, and also "BadBios!" Those malware systems can OVERWRITE any unprotected BIOS with modified code!
4/26/2017 8:05:43 PM • PC Chips... • Answered on Apr 26, 2017
Placa de baza m811 ver
Suporta procesor Amd Athlon 1,2Ghz-2,5Ghz,Ram DDR 3200 2Gb maxim
3/20/2015 3:27:09 PM • PC Chips... • Answered on Mar 20, 2015
How to find motherboard details on assembled p4 computers
on the board there are numbers near the pci slots or cpu socket area pci are white plastic slots look on the side of them too
5/25/2014 2:41:58 AM • PC Chips... • Answered on May 25, 2014
Computers & Internet Logo
18 questions posted
Top PC Chips Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a PC Chips Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • PC Chips Computers & Internet
Most Popular Question
system cannot detect integrated sound
  • Computers & Internet
