20 Most Recent
PC Chips P25G Motherboard Questions & Answers
Want to edit pdf text
There is a tool available in the market named Nitro PDF professional through which you can edit PDF files.
It is a paid tool or either you can try torrents.
Regards
Manjeet
Vt8237r Via chipset
http://www.pcchips.com.tw/PCCWebSite/Products/ProductsDetail.aspx?detailid=358&CategoryID=1&DetailName=Driver&MenuID=45&LanID=0
P25G v 1.0A. Was running
One of the sticks is probably defected when it runs with the other one. I would move them around slots to see if you can't get them both working.
My chipset motherboard P25G, bios
make sure metal tower is firmely tight on the black chip on mother board with braket tightley clamed on it.and also check fan make sure thats tight on mother board.
Computer shutdown
make sure this hard drive is getting power
Test or replace your PSU power supply unit
one bad/faulty lead can cause a computer with lots of problems continually rebooting or failing to detect your drive
replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps?
Wiring diagram
Hello, it appears to be available to download from the pc chips website, though you'll need to unzip it.
The website is :
http://www.pcchips.com.tw/PCCWebSite/Downloads/ProductsDetail_Download.aspx?detailid=358&DetailName=Manual&DetailDesc=&CategoryID=1&MenuID=6&LanID=0
Regards,
nicam49
My audia s not working
open goole home page download Driver magician instal after update serch all drives click audio drive opition driver version support relase date
google page open serch driver name version freedownload after instal problem slove its true ............try
Add a comment
Computer gets to the windows
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
good luck
Hi, there i have just downloaded a movie using
Hi. I think you should make sure first that the video you're downloading is already finish before you open it with your media player or maybe because your media player doesnt support the file type that you have downloaded, try downloading this media VLC Player, it could play almost all media type of file, just search it into google or type VLC Player Download it will output some websites to dwonload this player, then install it use it to play the video file that you have finish downloading. Hope This Helps
I built my own pc, it ran great for about 6
3 beeps is a good indication that video card is dead. Try the card in another slot if possible, or another PC. If it does not work, it is time for a new one. At 6 months old, you may have luck with a warranty. Contact the manufacturer. In the meanwhile, hit up the local PC repair shops for a cheap used card so you can at least limp around the internet while you solve you broken card problems.
Yahoo does not load properly - it just looks like
your screen resolution is at the wrong setting. try 1024 x 768 or 1 higher this will make the display format look smaller. click on control panel click on display click on settings. it is simple from there
I need the driver for the ethernet card on my PC
Go to the manufacture's website and download this driver. Please know what is model & the manufacturer of the ethernet card before downloading. To know this, go to the device manager. Follow the step below.
STEP: 1. Right click My Computer
2. Click Properties, Hardware, Device Manager
3. Double click Network Adapters, after that, the manufactures and model on the ethernet card will display.
Hope it will help!
Best regards,
Geloaa
