20 Most Recent Brother MFC-8440 All-In-One Laser Printer Questions & Answers
YOU HAVE TO RESET.
TURN OFF THEN PRESS THE STOP /CLEAR BUTTOM THEN TURN ON KEEP PRESS ABOUT 10 SECOND THEN IT WORK .
Brother MFC-8440... | Answered on May 17, 2019
https://help.brother-usa.com/app/answers/detail/a_id/145079/~/unable-to-print-6f
"Unable to Print 6F"
The message "Unable to Print 6F" will appear on the display for one of the following reasons:
i. A foreign object, such as a paper clip or ripped piece of paper, is stuck in the machine;
ii. Mechanical malfunction.
To attempt to clear the error, continue to step 1.
1. Using both hands, use the finger holds on each side of the machine to life the scanner cover into the open position.
- Do you see the scanner cover support arm located on the left side of the machine?
- If yes, go to step 2.
- If no, verify you have opened the scanner cover (as in the image above). If the document cover was opened, you won't see the scanner cover support arm. Close the document cover and go back to step 1 to open the scanner cover.
2. Carefully check the left (2) and right (3) hand corners and the center inside the machine and remove any paper scraps that may be jammed.
3. Using your hand, move the print head from left to right, checking carefully for any paper scraps stuck under the print head. Remove any if found.
If the print head is in the right-hand corner, press and hold down the for at least 5 seconds until the print head moves to the middle. This will allow you to check the right corner inside the machine for any paper scraps.
4. Leave the scanner cover open and turn the machine around so you are looking at the back of the machine.
5. Open the Jam Clear Cover (1) on the back of the machine.
6. Check inside for any foreign objects or jammed paper. Remove it found.
7. Close the Jam Clear Cover, then turn the machine back around to the front.
8. Lift the flat-bed scanner cover to release the lock (1), then gently push the scanner cover support down (2) and close the scanner cover (3) using both hands.
- If "Unable to Print 6F" still on the display, go to step 10.
- If "Unable to Print 6F" has cleared, go to step 11.
10. Unplug the machine from the power outlet for approximately one-minute, then plug it back in.
- If "Unable to Print 6F" still on the display, go to step 12.
11. Print a Print Quality Check Sheet (PQCS).
a. Press on the Touchscreen.
b. Press Test Print.
c. Press Print Quality.
d. Press OK. A PQCS will print.
- If the PQCS print successfully, your machine is working properly. The issue has been resolved.
- If the PQCS doesn't print because "Unable to Print 6F" reappears and you have not cycled the power, go back to step 10.
- If the PQCS doesn't print because "Unable to Print 6F" reappears and you have cycled the power, continue to step 12.
12. Your machine will require service. Any faxes received while the error message is on the display will automatically go into the machine's memory due to the product's inability to print. If there are faxes in memory, you can transfer them to another fax machine so they are not lost.
- If you don't want to transfer faxes, go to Warranty and Service Options.
- If you want to confirm and transfer received faxes in memory, go to step 13.
13. Transferring stored faxes to another machine.
To transfer data from your fax machine to another fax machine, you must have already programmed the Station ID in your machine prior to getting the "Unable to Print 6F" error message. If you did not already have your Station ID programmed into the machine before getting the error, you will not be able to transfer faxes in memory. Continue to Warranty and Service Options.
a. Press to temporarily interrupt the error message.
b. Press on the Touchscreen.
c. Press All Settings.
d. Press ? or ? to display Service. Press Service.
e. Press Data Transfer.
f. Press Fax Transfer.
- If "No Data" appears there are no faxes in memory to transfer. Press , then continue to Warranty and Service Options.
- If there are faxes in memory, the display will prompt to enter a fax number. Enter the fax number including the 1 plus the area code, then go to step g.
Warranty and Service Options:
Your machine has a two-year limited exchange warranty. You may use the link below to find a Brother-authorized service center in your area. You may also contact Customer Service for additional warranty options.
Locate a Brother Authorized Service Center:
https://www.brother-usa.com/service/
Contact Brother Customer Support:
https://www.brother-usa.com/askus/ Click here to display all models covered by this answer.
Was this answer helpful?
Brother MFC-8440... | Answered on Aug 13, 2018
3333 3333 3333 3333 3333
Brother MFC-8440... | Answered on Nov 22, 2017
is there a error message in the display, ley me kno what it is and i will try and help - brother tech
Brother MFC-8440... | Answered on Aug 19, 2017
sometimes a good long pair of tweezers helps , I use fishing forceps myself . have 4 different sizes from 2 inch to 14 inch
Brother MFC-8440... | Answered on Oct 27, 2015
please describe the noise? Burning smell like plastic?
It's a laser printer, so it's possible that the fuser is an issue. Is there a paper jam in the printer under the fuser?
Brother MFC-8440... | Answered on Feb 06, 2015
Your fuser unit is faulty, could be due to the thermistor in it.
Brother MFC-8440... | Answered on Dec 02, 2014
Check setting. Printer and Xerox machines are provided with button or software control for controlling blackness of print.
Brother MFC-8440... | Answered on Oct 04, 2014
Nothing to do, just shut off the printer and wait for 5 min. Then remove the tray and adjust the tray according to paper size and then try to print.
Brother MFC-8440... | Answered on Sep 01, 2014
I'm sure I did answer this one. Please don't put the same question here twice or even more. This is not google where you could have a response within .03 seconds and then you can't do anything with the one million hits.
Brother MFC-8440... | Answered on Jun 26, 2014
please check the fuser unit side
Brother MFC-8440... | Answered on May 10, 2014
this could be either the thermal fuse on the machine or the power suply. it means that the fuser on the machine is not heating up. this error would need servicing on the machine unfortunatly
Brother MFC-8440 All-In-One Laser Printer Logo
269 questions posted
James Cagle
James Cagle
Jim Keysor
ctnozil
View Most Popular
MFC Brother
  • MFC Brother
Most Popular Question
drum brother mfc 9840cdw needs replacing
  • Office Equipment & Supplies
