20 Most Recent Nor-Lake Walk In Cooler 6ft x 6ft x 7ft Norlake NO REFRIGERATION Questions & Answers
Unfortunately, this model has had quite a few problems, because it is such a complicated refrigerator. Many times a shorted component that is connected to the Iceland main control board will affect completely unrelated items making it easy to chase your tail for hours. I would suspect the freezer thermostor - only because we have had to replace it many times in the past.
Suggest you go to the www.searspartsdirect.com and copy the electrical diagram and then verify electrical reading on the main PCB, to try to isolate the problem.
Nor-Lake... | Answered on Jan 26, 2012
There are a few companys that make temp chart recorders that are battery controled and you could get one of these and just put it inside the refrigerator, problem solved. Check at United Refrigeration, and Johnstone Supply they both have manufacturers that will allow you to keep charts. The 2 things to keep in mind 1 How often are you going to change charts, 2 what temperature range are you looking for.
Oh yes and Im sure there is a company that makes a remote sensed temp recorder that can tie into a computer and print out charts as needed. This is a little more specialized but I know the technology is asvailable. Probably Johnson or Penn Controls would know about this.
If this helps you in any way please rate me as high as you can. If you need to contact me and I can do the searching for you post back.
Nor-Lake... | Answered on May 29, 2009
Call the manufacturer with the information and they will send you the correct parts.
Usually for free being it's brand new.
parts 888-837-1380 8-5 pst
Home Depot- Lone Star Charcoal Grill
Refrigerators | Answered 4 hours ago
Sounds more like a temperature sensor or control
It has a microprocessor that can do a self diagnosing
This is a special lab product
There number is 1-800-858-8442
Refrigerators | Answered 5 hours ago
Unlock the wheels? Usually there is a leg with a rubber cap on it that is preventing the refrigerator to move.
remove the front grill and use a flashlight to look at the front Left and right for the leg and see if the wheels are available
You should have used the ultimate it comes with the plugs for the capacitor.
you can splice it between the start and run wires that go from the RC to the compressor using a spade connectors
Refrigerators Logo
1 questions posted
Top Nor-Lake Refrigerators Experts
Marvin
Marvin
Marat Brikov
Are you a Nor-Lake Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
  • Nor-Lake Refrigerators
Most Popular Question
type refrigerant
  • Refrigerators
