20 Most Recent
Grizzly Big Bear Atv Maintenance Free Battery Questions & Answers
How to install horn
power to switch then from switch to horn other side needs to be grounded usually marked pos neg
Yamaha grizzly 660 shift linkage adjustment
Will it not go into park or will the light not come on? If it goes into park look at the switch.
Check and make sure there is nothing binding the shift linkage or that the linkage is not bent. If all looks good adjust it.
Adjust your shift linkage just enough for it to go into park. Then check engagement in other positions
Shifter moves on big bear 350 but quad wont reverse now it goes forwards
for some reason you are not getting into reverse , there is no real reason it should stay in forward gears unless there is someting wrong with the shifter itself being in the wrong position this can happen take it off and reposition it and make sure your clutch is disengauging to shift gears , will it go into all gears or just 1 forward , ck into that and be a little more specific on the problem ,good luck
Big bear atv run one hundred meters then mortor stops
Sounds like a fuel problem. Try running the atv with the fuel cap loose. If it runs ok you need a new (vented) fuel cap. If the cap isn't the problem, check the fuel filter (if equipped). Remove filter and blow through it. If it is hard to blow through, replace filter. Also, check for kinked or pinched fuel lines between tank and carbs, and also the vent hoses from the carbs (if equipped).
